用JLINK进行RAM调试时,程序中NVIC初始化后程序就会卡死,注释掉“NVIC_Init(&NVIC_InitStructure);”就可以正常运行,求大神帮看
这里附上main.c的程序- /*Include---------------------------*/
- #include"stm32f10x_lib.h" //包含所有的头文件
- #include<stdio.h>
- //----------------函数声明--------------------
- void Delay_MS(u16 dly);
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- //void EXTI_Configuration(void);
- void NVIC_Configuration(void);
- //void USART3_Configuration(void);
- * Function Name : main
- * Description : Main program.
- * Input : None
- * Output : None
- * Return : None
- int main(void)
- #ifdef DEBUG
- debug();
- #endif
- //------------初始化------------
- RCC_Configuration();
- GPIO_Configuration();
- // EXTI_Configuration();
- NVIC_Configuration();
- // USART3_Configuration();
- while(1)
- GPIO_SetBits(GPIOA, GPIO_Pin_1); //置位LED
- Delay_MS(2000);
- GPIO_ResetBits(GPIOA, GPIO_Pin_1); //复位LED
- Delay_MS(2000);
- GPIO_SetBits(GPIOA, GPIO_Pin_4);
- Delay_MS(2000);
- GPIO_ResetBits(GPIOA, GPIO_Pin_4);
- Delay_MS(2000);
- * Function Name : Delay_Ms
- * Description : delay 1 ms.
- * Input : dly (ms)
- * Output : None
- * Return : None
- u16 i,j;
- for(i=0;i<dly;i++)
- for(j=1000;j>0;j--);
- * Function Name : RCC_Configuration
- * Description : Configures the different system clocks.
- * Input : None
- * Output : None
- * Return : None
- //----------使用外部RC晶振-----------
- RCC_DeInit(); //初始化为缺省值
- RCC_HSEConfig(RCC_HSE_ON); //使能外部的高速时钟
- while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET); //等待外部高速时钟使能就绪
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Enable Prefetch Buffer
- FLASH_SetLatency(FLASH_Latency_2); //Flash 2 wait state
- RCC_HCLKConfig(RCC_SYSCLK_Div1); //HCLK = SYSCLK
- RCC_PCLK2Config(RCC_HCLK_Div1); //PCLK2 = HCLK
- RCC_PCLK1Config(RCC_HCLK_Div2); //PCLK1 = HCLK/2
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9); //PLLCLK = 8MHZ * 9 =72MHZ
- RCC_PLLCmd(ENABLE); //Enable PLLCLK
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //Wait till PLLCLK is ready
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock
- while(RCC_GetSYSCLKSource()!=0x08); //Wait till PLL is used as system clock source
- //---------打开相应外设时钟--------------------
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //使能APB2外设的GPIOA的时钟
- //RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE); //使能APB2外设的GPIOA的时钟
- * Function Name : GPIO_Configuration
- * Description : 初始化GPIO外设
- * Input : None
- * Output : None
- * Return : None
- GPIO_InitTypeDef GPIO_InitStructure; //声明一个结构体变量
- EXTI_InitTypeDef EXTI_InitStructure;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_1; //选择PC.10(TXD) 和 PC.11
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管脚频率为50MHZ
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //输出模式为复用推挽输出
- GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化GPIOC寄存器
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //选择PC.10(TXD) 和 PC.11
- GPIO_Init(GPIOC,&GPIO_InitStructure); //初始化GPIOC寄存器
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; //选择PC.10(TXD) 和 PC.11(RXD)
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //输出模式为浮空输入
- GPIO_Init(GPIOC,&GPIO_InitStructure); //初始化GPIOA寄存器
- GPIO_EXTILineConfig(GPIO_PortSourceGPIOC,GPIO_PinSource13);
- //EXTI_DeInit(); //将EXIT寄存器重设置为缺省值
- EXTI_InitStructure.EXTI_Line = EXTI_Line13;
- EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
- EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
- EXTI_InitStructure.EXTI_LineCmd = ENABLE;
- EXTI_Init(&EXTI_InitStructure);
- //将USART3的TXD和RXD重映射到PC10和pc11
- //GPIO_PinRemapConfig(GPIO_PartialRemap_USART3,ENABLE);
- // EXTI_InitTypeDef EXTI_InitStructure;
- // EXTI_DeInit(); //将EXIT寄存器重设置为缺省值
- // EXTI_InitStructure.EXTI_Line = EXTI_Line13;
- // EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
- // EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
- // EXTI_InitStructure.EXTI_LineCmd = ENABLE;
- // EXTI_Init(&EXTI_InitStructure);
- // EXTI_ClearITPendingBit(EXTI_Line13);
- NVIC_InitTypeDef NVIC_InitStructure;
- #ifdef VECT_TAB_RAM
- NVIC_SetVectorTable(NVIC_VectTab_RAM,0X0);//向量表位于RAM区
- #else
- NVIC_SetVectorTable(NVIC_VectTab_FLASH,0X0);//向量表位于FLASH区
- #endif
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
- NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQChannel;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- // USART_InitTypeDef U3;
- // U3.USART_BaudRate =9600;
- // U3.USART_WordLength = USART_WordLength_8b;
- // U3.USART_StopBits = USART_StopBits_1;
- // U3.USART_Parity = USART_Parity_No;
- // U3.USART_Mode = USART_Mode_Rx|USART_Mode_Tx;
- // U3.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- // USART_Init(USART3, &U3);
- // USART_Cmd(USART3,ENABLE);
