[i.MX] imx6q SabreLite u-boot编译问题
 楼主| Nerror 发表于 2014-10-17 14:11 | 显示全部楼层 |阅读模式
u-boot 和 SDK 在embest官网下载的和timesys上下载的都一样,编译内核没有问题,编译u-boot时遇到的问题:
make -C tools all
make[1]: 正在进入目录 `/home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/tools'
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/include/libfdt_env.h -idirafter /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/include -idirafter /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/include2 -idirafter /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/include -I /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/lib/libfdt -I /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/tools -DCONFIG_SYS_TEXT_BASE=0x17800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -pedantic   -o bmp_**.o bmp_**.c -c
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/include/libfdt_env.h -idirafter /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/include -idirafter /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/include2 -idirafter /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/include -I /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/lib/libfdt -I /home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/tools -DCONFIG_SYS_TEXT_BASE=0x17800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -pedantic  -o bmp_** bmp_**.o
strip bmp_**
strip: Unable to recognise the format of the input file `bmp_**'
make[1]: *** [bmp_**] 错误 1
make[1]:正在离开目录 `/home/lg/timesys/i_MX6QSABRELite/u-boot-2013.07/tools'
make: *** [tools] 错误 2
起初以为Ubuntu版本问题,试过11.10、12.04.1、12.04.5、14.04,都一样。
不知还有谁也遇到过?
SabreLite开发板是在英蓓特买的,发邮件和在他的论坛上询问,无人回复。想在这里问一下,哪位大侠遇到过?
FSL_TICS_Rita 发表于 2014-10-17 14:22 | 显示全部楼层
楼主你好,请问你使用的是哪个版本的BSP?
 楼主| Nerror 发表于 2014-10-17 14:57 | 显示全部楼层
Ubuntu 14.04.1
boot: u-boot-2013.07.tar.bz2
sdk:  i.MX6QSABRELite-development-environment.sh
core: Linux-3.0.35
toolchain:armv7l-timesys-linux-gnueabi-
都是从timesys网站下载的
 楼主| Nerror 发表于 2014-10-17 17:13 | 显示全部楼层
用的是 gcc-4.7.3
FSL_TICS_Rita 发表于 2014-10-20 11:16 | 显示全部楼层
Ubuntu 14.04.1
楼主你好,你使用的BSP不是飞思卡尔官网的,所以不知道你使用的BSP是怎样的结构,这里建议你到你购买的开发板的官网寻求帮助。他们的技术支持应该会给你一些方案和解决办法。
你这里是**显示出现的问题,不知道他们在哪些内容上做了修改,我们不好给出一些建议的,建议你先找一下提供给你软件的公司询问一下。后续有问题,我们再讨论哈~~
 楼主| Nerror 发表于 2014-10-20 11:20 | 显示全部楼层
难道用英蓓特 SabreLite 开发板的都没遇到过?
 楼主| Nerror 发表于 2014-10-20 11:36 | 显示全部楼层
多谢 FSL_TICS_Rita 的回复。
FSL_TICS_Rita 发表于 2014-10-20 15:27 | 显示全部楼层
我们这边遇到的问题都是关于飞思卡尔开发板,已经参考我们官网板子遇到的问题。关于英贝特开发板的问题,软件硬件都不是我们设计的,所以也不好定位是哪里的问题。非常抱歉,希望你能理解哈~~
FSL_TICS_Rita 发表于 2014-10-20 15:28 | 显示全部楼层
不客气的,欢迎楼主有问题继续在本论坛中提问哈,我们的工程师会给你最快的回复或者建议。
FSL_TICS_Rita 发表于 2014-10-20 15:29 | 显示全部楼层
楼主你好,如果您的问题已经解决的话,麻烦帮忙结帖哈~~非常感谢~~
FSL_TICS_Rita 发表于 2014-10-20 15:30 | 显示全部楼层
结帖方式参考本论坛中的帖子:https://bbs.21ic.com/icview-692566-1-1.html
