输入共模电压超过范围了,可以用电阻分压再接到LM393的输入引脚。
LM393-TI规格书第4页:
The upper end of the commonmode voltage range is VCC+ – 1.5 V for the inverting input (–), and the non-inverting input (+) can exceed the VCC level; the comparator provides a proper output state.
