有人知道用LPC2378,用以太网口发送DNS请求吗?
 楼主| bjluhaijun 发表于 2008-4-2 15:01 | 显示全部楼层 |阅读模式
armecos 发表于 2008-4-2 15:25 | 显示全部楼层
DNS和2378没关系
<b>DNS</b><br />可在www.armecos.com下载完整文档。<br /><br />请问那位高手移植过动态域名解析程序到ARM上<br />lizhenarm&nbsp;发表于&nbsp;2006-2-22&nbsp;09:22&nbsp;ZLG-ARM<br /><br /><br />你看看RFC1034/1035就知道如何写DNS程序了<br />gdtyy&nbsp;发表于&nbsp;2006-2-22&nbsp;18:07:58&nbsp;ZLG-ARM<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;你按照协议要求组成一个请求包,然后解析应答包内容就可以从域名得到IP地址。下面有一个示例,你可以参考一下。一般在单片机里实现的DNS就是指域名到IP转换,不必实现完整协议。你可以试试在ECOS或LINUX里找源码。<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;因为对外的IP地址可能动态变化,所以最好用域名,方便用户访问。<br />&nbsp;&nbsp;&nbsp;&nbsp;可以使用代理网关,或者ADSL,或CDMA等连接公网,关键是得到公网IP才能被访问,否则只能发起主动连接。当得到动态公网IP时,就刷新DNS,用户用DNS就能间接访问到WEB。<br /><br />www.163.com域名解析实例(2005/03/08&nbsp;12:45&nbsp;test&nbsp;by&nbsp;YangYi)<br /><br />dns&nbsp;send&nbsp;29&nbsp;bytes:0,0,1,0,0,1,0,0,0,0,0,0,3,77,77,77,3,31,36,33,3,63,6f,6d,0,0,1,0,1<br /><br />dns&nbsp;recv&nbsp;230&nbsp;bytes:0,0,81,80,0,1,0,6,0,2,0,2,3,77,77,77,3,31,36,33,3,63,6f,6d,0,<br />0,1,0,1,c0,c,0,5,0,1,0,0,3a,c9,0,1d,3,77,77,77,5,63,61,63,68,65,5,73,70,6c,69,74<br />,7,6e,65,74,65,61,73,65,3,63,6f,6d,0,c0,29,0,1,0,1,0,0,8,60,0,4,ca,6a,a8,6d,c0,2<br />9,0,1,0,1,0,0,8,60,0,4,ca,6a,a8,79,c0,29,0,1,0,1,0,0,8,60,0,4,ca,6c,24,99,c0,29,<br />0,1,0,1,0,0,8,60,0,4,ca,6a,a8,67,c0,29,0,1,0,1,0,0,8,60,0,4,ca,6a,a8,68,c0,33,0,<br />2,0,1,0,0,40,a0,0,c,9,6e,73,2d,73,70,6c,69,74,32,c0,39,c0,33,0,2,0,1,0,0,40,a0,0<br />,c,9,6e,73,2d,73,70,6c,69,74,31,c0,39,c0,a2,0,1,0,1,0,0,3a,be,0,4,ca,6a,ba,7d,c0<br />,ba,0,1,0,1,0,0,3a,b0,0,4,ca,6a,a8,4f<br /><br />PASS:&ltwww.cache.split.netease.com.&nbsp;is&nbsp;202.106.168.109&gt<br /><br />name&nbsp;=&nbsp;&quot;www.163.com&quot;&nbsp;&lt-----&gt&nbsp;IP&nbsp;=&nbsp;202.106.168.109
 楼主| bjluhaijun 发表于 2008-4-6 18:18 | 显示全部楼层
感谢2楼指点
感谢2楼指点
