[AVR单片机] 外部中断为何引起复位
 楼主| 康鹏鹏 发表于 2015-5-6 13:38 | 显示全部楼层 |阅读模式
//ICC-AVR application builder : 2015/5/5 23:40:48
// Target : T13
// Crystal: 9.6000Mhz
#include <iot13v.h>
#include <macros.h>
#define Led_on PORTB&=0xfe
#define Led_off PORTB|=0x01
#define key1 (PINB&0x08)
#define key2 (PINB&0x10)
#define Light (PINB&0x04)
#define uchar unsigned char
#define uint unsigned int
#define Mode_one_on 50
#define Mode_one_off 50
#define Mode_two_on 10
#define Mode_two_off 80
#define DJ 1000
uint time=0;
uchar mode=1;
uchar time_on;
uchar time_off;
static uchar shanshuo_time;
void Sleep(void)
Led_off;
GIMSK |= 0X60; //外部中断0使能
SEI();
MCUCR|=0x30;    //掉电模式
asm("sleep");
/*************************************LED灯控制********************************/
void LED(void)
if(mode==1)
  if(shanshuo_time<Mode_one_on)Led_on;
  if((shanshuo_time>Mode_one_on)&&(shanshuo_time<(Mode_one_on+Mode_one_off)));Led_off;
  if(shanshuo_time>=(Mode_one_on+Mode_one_off))
   shanshuo_time=0;
if(mode==2&&Light!=0)
  if(shanshuo_time<Mode_two_on)Led_on;
  if((shanshuo_time>Mode_two_on)&&(shanshuo_time<(Mode_two_on+Mode_two_off)))Led_off;
  if(shanshuo_time>=(Mode_two_on+Mode_two_off))
   Led_off;
   shanshuo_time=0;
if(mode==3)Sleep();
/*****************按键检查******************************/
uchar Keyscan(void)
uchar key_mode;
if(key1==0)key_mode=1;
if(key2==0)key_mode=2;
if(key1!=0&&key2!=0)key_mode=3;
return key_mode;
void port_init(void)
PORTB = 0x3F;
DDRB  = 0x01;
//TIMER0 initialize - prescale:1024
// WGM: Normal
// desired value: 10mSec
// actual value:  9.920mSec (0.8%)
void timer0_init(void)
TCCR0B = 0x00; //stop
OCR0A = 0x5D;
OCR0B = 0x5D;
TCNT0 = 0xA3; //set count
TCCR0A = 0x00;
TCCR0B = 0x05; //start timer
#pragma interrupt_handler timer0_ovf_isr:iv_TIM0_OVF
void timer0_ovf_isr(void)
TCNT0 = 0xA3; //reload counter value
time++;
shanshuo_time++;
if(time>=DJ)Sleep();
#pragma interrupt_handler int0_isr:iv_INT0
void int0_isr(void)
//external interupt on INT0
time=0;
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
timer0_init();
MCUCR = 0x01;
PCMSK=0X02;
TIMSK0 = 0x02; //timer interrupt sources
GIMSK = 0x60; //interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
void main(void)
init_devices();
while(1)
  mode=Keyscan();
  LED();
为何我的外部中断,会引起复位呢?实在搞不懂
JY-DX-JY 发表于 2015-5-6 16:05 | 显示全部楼层
干扰。
csust_omega 发表于 2015-5-6 17:34 | 显示全部楼层
楼主如何确定是由外部中断引起的?查过电源,查过复位引脚了么
 楼主| 康鹏鹏 发表于 2015-5-6 19:34 | 显示全部楼层
你好  我接线是没有接复位脚的,已经检查清楚。
 楼主| 康鹏鹏 发表于 2015-5-6 19:35 | 显示全部楼层
你好,请问是什么干扰呢,
JY-DX-JY 发表于 2015-5-6 19:36 | 显示全部楼层
我只能想到这个。
 楼主| 康鹏鹏 发表于 2015-5-6 20:06 | 显示全部楼层
我只能想到这个。
谢谢,主要是低电平触发不会复位,但是引脚电平变化触发就进入复位了
hyhmh 发表于 2015-5-7 08:58 | 显示全部楼层
外部中断触发运行的代码死锁?若开了WDT,则会复位。
另一外可能是:外部中断的“信号”已经超出了板上MCU的承受力(与电路、板子设计都有关),引起MCU复位。
