看代码的话就是说,cpu_is_am33xx成立的话就执行 *base = 0x8000000;*size = 0x10000000;,是cpu决定了地址跟大小.
看看board里面的static void evm_nand_init(int evm_id, int profile)
struct omap_nand_platform_data *pdata;
struct gpmc_devices_info gpmc_device[2] = {
{ NULL, 0 },
{ NULL, 0 },
setup_pin_mux(nand_pin_mux);
pdata = omap_nand_init(am335x_nand_partitions,
ARRAY_SIZE(am335x_nand_partitions), 0, 0,
&am335x_nand_timings);
if (!pdata)
return;
pdata->ecc_opt =OMAP_ECC_BCH8_CODE_HW;
pdata->elm_used = true;
gpmc_device[0].pdata = pdata;
gpmc_device[0].flag = GPMC_DEVICE_NAND;
omap_init_gpmc(gpmc_device, sizeof(gpmc_device));
omap_init_elm();
这个是不是有冲突......
