[技术问题解答] k60 SPI时钟最高速度
 楼主| zding92 发表于 2015-7-28 15:04 | 显示全部楼层 |阅读模式
I'm using K60 MK60DN512VLQ10. I want to ask what's the highest speed of the SPI Clock of this chip in the mode of Master and Slave? Thanks
追逐浪花 发表于 2015-7-28 20:42 | 显示全部楼层
为啥要用英语问呢,能不能用中文?
FSL_TICS_ZJJ 发表于 2015-7-29 09:33 | 显示全部楼层
Thank you for your interest in Freescale kinetis product, I would like to provide service for you.
Actually, the datasheet have the max frequent for K60 SPI operation frequency.
About the Master mode, the SPI max  operation frequency is 25Mhz.
About the Slave mode, the SPI max operation frequency is 12.5Mhz.
For details, please refer to document K60P144M100SF2V2.pdf, the document link is:
http://cache.freescale.com/files ... on&fileExt=.pdf
Wish it helps you!
If you still have question, please contact me!
