[开发工具] 在 KEIL 下这样实现了“读保护”,请大家来评论是否可靠
5924|8
 楼主| luyuc 发表于 2009-6-2 11:19 | 显示全部楼层 |阅读模式
keil, TE, TI, se, ST
   首先打开WINDOWS任务管理器
1.上 KEIL 进入 DEBUG 状态
2.读取地址  0X1FFF F800 , 显示出内容 0X00FF 5AA5
3.修改最低8位为 FF , 这时数据为  0X00FF 5AFF
4.KEIL 死掉
5.在任务管理器中结束 KEIL
    Reading/programming the STM32F10xxx embedded Flash memory PM0042  17 页这样写
This protection is activated by setting the RDP option byte. Once the protection byte has been programmed to a value:
● Main Flash memory read access is not allowed except for the user code (when booting from main Flash memory itself with the debug mode not active).
● Pages 0-3 (for low- and medium-density devices), or pages 0-1 (for high-density devices) are automatically write-protected. The rest of the memory can be programmed by the code executed from the main Flash memory (for IAP, constant storage, etc.), but it is protected against write/erase (but not against mass erase) in debug mode or when booting from the embedded SRAM.
● All features linked to loading code into and executing code from the embedded SRAM are still active (JTAG/SWD and boot from embedded SRAM) and this can be used to Reading/programming the STM32F10xxx embedded Flash memory PM0042 disable the read protection. When the read protection option byte is altered to a memory-unprotect value, a mass erase is performed.
computer00 发表于 2009-6-2 11:28 | 显示全部楼层
FLASH不能直接这样修改吧……你再读回来看看?
应该在程序中用at关键字指定地址的值
grant_jx 发表于 2009-6-2 19:59 | 显示全部楼层
这样在MDK下改,肯定不可靠。
STM32的外设固件库中Flash API下面不是有这个函数吗?难道不能实现要求?
* Function Name  : FLASH_ReadOutProtection
* Description    : Enables or disables the read out protection.
*                  If the user has already programmed the other option bytes before
*                  calling this function, he must re-program them since this
*                  function erases all option bytes.
* Input          : - Newstate: new state of the ReadOut Protection.
*                    This parameter can be: ENABLE or DISABLE.
* Output         : None
* Return         : FLASH Status: The returned value can be: FLASH_BUSY,
*                  FLASH_ERROR_PG, FLASH_ERROR_WRP, FLASH_COMPLETE or
*                  FLASH_TIMEOUT.
FLASH_Status FLASH_ReadOutProtection(FunctionalState NewState)
  FLASH_Status status = FLASH_COMPLETE;
  /* Check the parameters */
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  status = FLASH_WaitForLastOperation(EraseTimeout);
  if(status == FLASH_COMPLETE)
    /* Authorizes the small information block programming */
    FLASH->OPTKEYR = FLASH_KEY1;
    FLASH->OPTKEYR = FLASH_KEY2;
    FLASH->CR |= CR_OPTER_Set;
    FLASH->CR |= CR_STRT_Set;
    /* Wait for last operation to be completed */
      /* if the erase operation is completed, disable the OPTER Bit */
      FLASH->CR &= CR_OPTER_Reset;
      /* Enable the Option Bytes Programming operation */
      FLASH->CR |= CR_OPTPG_Set;
      if(NewState != DISABLE)
        OB->RDP = 0x00;
      else
        OB->RDP = RDP_Key;
      if(status != FLASH_BUSY)
        /* if the program operation is completed, disable the OPTPG Bit */
        FLASH->CR &= CR_OPTPG_Reset;
    else
        /* Disable the OPTER Bit */
  /* Return the protection operation Status */
  return status;
非要在Keil里面改?不知意图是什么,是否是希望keil的编程能支持读保护操作,还是在调试的时候可以实现读保护功能的调试,我自己给自己的话快绕晕了。
 楼主| luyuc 发表于 2009-6-3 20:38 | 显示全部楼层
是这样
1. 我完全用汇编在 keil 写东西
2. 我调完后就想直接锁住(量小的生产)
3. 板上只留 4 根针 gnd  swdio swclj vdd ,方便
 楼主| luyuc 发表于 2009-6-3 20:48 | 显示全部楼层
在 keil 用间接寻址操作0X1FFF F800无效
1.我也曾想过,在复位后,让程序操作地址 0x1FFF F800 ,但是试了一下,不行;可能还有别的时序要求,如什么 KEY 之类,文档也没有仔细看;
2.我在数据窗口读出 0X1FFF F8000 后,修改低2位,回车就导致 KEIL 死掉;
3.我用KEIL挂 STLINK2 学习板学软件,这搭配本身就不理想;
4.后来我尝试了别的地址,只要不是 FLASH 内的地址,一动数据回车就死 KEIL,真实有趣;
5.如果动 FLASH 的某些地址的数据,发现 KEIL 的程序指针自己走几下,有趣;
 楼主| luyuc 发表于 2009-6-3 21:02 | 显示全部楼层
我写很多小汇编测试外设
发现这样 HEX 文件比较小,编译后一般在 2.5K 以下,挂上 C 头文件马上就有近 10K 不见了,这的确是让人担心用 C 写东西,32K 也不太够折腾的;还是下点功夫,把汇编的外设测试例程都完善了吧,这样比较让人放心,我也基本上看不懂 C ; 如果我把 3 楼给的那段 C 译成汇编,让芯片复位后自己走一次,相信马上可以实现读保护,这里谢谢 3 楼的朋友了;
 楼主| luyuc 发表于 2009-6-3 22:40 | 显示全部楼层
大概是这样的,不知道对否
   看了看文档,首先确定一点,通过 IDE 界面无法实现读保护操作,让程序自己跑起来可以实现这一操作;如下几步:
1. 使能 HSI
2. FPEC 解锁
3. 写入 KEY1 到 FLASH_OPTKEYR
4. 写入 KEY2 到 FLASH_OPTKEYR
5. 设置 FLASH_CR 的OPTWRE 位为 1
6. 对选择字节进行编程
   有几个问题不明白
1. 写入 KEY1  KEY2 就是解锁 FPEC 吧?
2. 置位 OPTWRE 位是进行半字的普通写入操作吧?
3. 进行选择字节的编程也应该是进行半字的普通写入操作吧?
4. 一旦学习板读保护成功了,我也就不能再用了,必须进入 RAM 启动,清除读保护后,才能 DEBUG 吧? 至今试了几次,还没有成功从 RAM 启动过;所以万万不可自己把自己搞定了;
5. 如果把这一段代码写入芯片复位后的位置,每次启动都执行一遍,感觉也不是太理想,是否存在寿命之类的问题呢,万一操作失败,是否整个程序就完了?
  想来想去,都无法放心用 SWDIO SWCLK 这两条线完成调试、读保护的操作;
FAQ 发表于 2017-11-7 23:21 | 显示全部楼层
nyszx 发表于 2017-11-8 13:10 | 显示全部楼层
挖坟了
