[ZLG-ARM] LPC2478 usb HOST
 楼主| qq_xiaoxin 发表于 2009-10-10 10:05 | 显示全部楼层 |阅读模式
请问周工,我用的2478,打算用来读U盘,但是枚举的时候出错USB_INT32S  Host_EnumDev (void)
    USB_INT32S  rc;
  //  PRINT_Log("Connect a Mass Storage device\n\r");
   while (!HOST_RhscIntr);
    Host_DelayMS(100);                             // USB 2.0 spec says atleast 50ms delay beore port reset
   HcRhPortStatus |= OR_RH_PORT_PRS;                                  // Apply port reset
执行这里的时候U盘灯量了
    Host_DelayMS(100);                                                 // Wait for 100 MS after port reset
    EDCtrl->Control = 8 << 16;                                         // Put max pkt size = 8
        // Read first 8 bytes of device desc
    rc = HOST_GET_DESCRIPTOR(USB_DESCRIPTOR_TYPE_DEVICE, 0, TDBuffer, 8);
    if (rc != OK) {
       // PRINT_Err(rc);
        return (rc);
    EDCtrl->Control = TDBuffer[7] << 16;                               // Get max pkt size of endpoint 0
    rc = HOST_SET_ADDRESS(1);                                          // Set the device address to 1
    if (rc != OK) {
        //PRINT_Err(rc);
        return (rc);
    Host_DelayMS(2);
    EDCtrl->Control = (EDCtrl->Control) | 1;                          // Modify control pipe with address 1
        // Get the configuration descriptor
   rc = HOST_GET_DESCRIPTOR(USB_DESCRIPTOR_TYPE_CONFIGURATION, 0, TDBuffer, 9);
    if (rc != OK) {
      //  PRINT_Err(rc);
        return (rc);
        // Get the first configuration data
    rc = HOST_GET_DESCRIPTOR(USB_DESCRIPTOR_TYPE_CONFIGURATION, 0, TDBuffer, ReadLE16U(&TDBuffer[2]));
    if (rc != OK) {
     //   PRINT_Err(rc);
        return (rc);
    rc = MS_ParseConfiguration();                                      // Parse the configuration
    if (rc != OK) {
       // PRINT_Err(rc);
        return (rc);
    rc = USBH_SET_CONFIGURATION(1);                                    // Select device configuration 1
    if (rc != OK) {
       // PRINT_Err(rc);
    Host_DelayMS(100);                                               // Some devices may require this delay
    return (rc);
读取设备描述的时候返回错误,请问我应该从哪个地方去找问题
