[DSP编程] 问下这段FIR滤波程序
 楼主| nwx8899 发表于 2016-4-19 10:17 | 显示全部楼层 |阅读模式
#define        N                 10         // number of FIR coefficients.
#define        BLKSIZE        20        // block size of samples filtered each time.
#define        M                 (N + BLKSIZE - 1)
float workbuf[M] = {0};        // history + current input block, initialize to 0.
// float h[N]: array of fir filter coefficients.
// float x[BLKSIZE]: array of input samples block
// float y[BLKSIZE]: array of samples block after filtering
void fir(float h[N], float x[BLKSIZE], float y[BLKSIZE])
        int i, j;
        float *p;
        // copy current input block to work buffer
        // workbuf[N-1] = x[0], workbuf[N] = x[1],
        // workbuf[N+1] = x[2], ..., workbuf[M-1] = x[BLKSIZE-1];
        for (i=0; i<BLKSIZE; i++)
                workbuf[i+N-1] = x;
        // FIR filter loop
                p = &workbuf[i+N-1];// each y needs right starting x.
                for (j=0; j<N; j++)
                        y += (h[j] * (*p--));
        // copy last N-1 samples of x[n] to workbuf
        // as history for next block
        p = &x[BLKSIZE-1];        // p points the last element;
        for (i=0; i<N-1; i++)
                workbuf[N-2-i] = *p--;
代码源自本论坛
没看明白,滤波的结果大了将近一倍的样子。
疑问是:如果一个周期的采样数BLKSIZE远远小于滤波器系数的个数N。
那后面
s the last element;
这句话怎么理解。
个人签名: 宁静致远
61
