[应用方案] ESP8266接入yeelink
 楼主| cowboy2014 发表于 2016-11-20 20:28 | 显示全部楼层 |阅读模式
搞定了SmartConfig,前头也用cURL玩过了yeelink,今天就编写代码,让ESP8266接入yeelink
一、代码处理。主要是将httpsample加入到SmartConfig_DEMO中。ESP8266的运行流程是SmartConfig->DNS->Connect yeelink->Get /devices
这里的pheadbuffer 格式要注意加上U-ApiKey。我是通过wireshark捕捉了curl Get /devices的动作才知道要怎么写的。
  1. #include "ets_sys.h"
  2. #include "osapi.h"
  3.
  4. #include "user_interface.h"
  5. #include "smartconfig.h"
  6.
  7. #include "espconn.h"
  8. #include "mem.h"
  9.
  10.
  11. #define NET_DOMAIN "api.yeelink.net"
  12. #define pheadbuffer "GET /v1.0/devices HTTP/1.1\r\nHost: %s\r\nAccept: */*\r\nU-ApiKey: e510ad132988d34c6fc9c3a9322f6f10\r\n\r\n"
  13.
  14. #define packet_size   (2 * 1024)
  15.
  16. LOCAL os_timer_t test_timer;
  17. LOCAL struct espconn user_tcp_conn;
  18. LOCAL struct _esp_tcp user_tcp;
  19. ip_addr_t tcp_server_ip;
  20.
  21. /******************************************************************************
  22. * FunctionName : user_tcp_recv_cb
  23. * Description  : receive callback.
  24. * Parameters   : arg -- Additional argument to pass to the callback function
  25. * Returns      : none
  26. *******************************************************************************/
  27. LOCAL void ICACHE_FLASH_ATTR
  28. user_tcp_recv_cb(void *arg, char *pusrdata, unsigned short length)
  29. {
  30.    //received some data from tcp connection
  31.
  32.     os_printf("tcp recv !!! %s \r\n", pusrdata);
  33. }
  34.
  35. /******************************************************************************
  36. * FunctionName : user_tcp_sent_cb
  37. * Description  : data sent callback.
  38. * Parameters   : arg -- Additional argument to pass to the callback function
  39. * Returns      : none
  40. *******************************************************************************/
  41. LOCAL void ICACHE_FLASH_ATTR
  42. user_tcp_sent_cb(void *arg)
  43. {
  44.    //data sent successfully
  45.
  46.     os_printf("tcp sent succeed !!! \r\n");
  47. }
  48. /******************************************************************************
  49. * FunctionName : user_tcp_discon_cb
  50. * Description  : disconnect callback.
  51. * Parameters   : arg -- Additional argument to pass to the callback function
  52. * Returns      : none
  53. *******************************************************************************/
  54. LOCAL void ICACHE_FLASH_ATTR
  55. user_tcp_discon_cb(void *arg)
  56. {
  57.    //tcp disconnect successfully
  58.
  59.     os_printf("tcp disconnect succeed !!! \r\n");
  60. }
  2. * FunctionName : user_esp_platform_sent
  3. * Description  : Processing the application data and sending it to the host
  4. * Parameters   : pespconn -- the espconn used to connetion with the host
  5. * Returns      : none
  8. user_sent_data(struct espconn *pespconn)
  9. {
  10.     char *pbuf = (char *)os_zalloc(packet_size);
  11.
  12.     os_sprintf(pbuf, pheadbuffer, NET_DOMAIN);
  13.
  14.     espconn_sent(pespconn, pbuf, os_strlen(pbuf));
  15.
  16.     os_free(pbuf);
  17.
  18. }
  19.
  20. /******************************************************************************
  21. * FunctionName : user_tcp_connect_cb
  22. * Description  : A new incoming tcp connection has been connected.
  23. * Parameters   : arg -- Additional argument to pass to the callback function
  24. * Returns      : none
  25. *******************************************************************************/
  26. LOCAL void ICACHE_FLASH_ATTR
  27. user_tcp_connect_cb(void *arg)
  28. {
  29.     struct espconn *pespconn = arg;
  30.
  31.     os_printf("connect succeed !!! \r\n");
  32.
  33.     espconn_regist_recvcb(pespconn, user_tcp_recv_cb);
  34.     espconn_regist_sentcb(pespconn, user_tcp_sent_cb);
  35.     espconn_regist_disconcb(pespconn, user_tcp_discon_cb);
  36.
  37.     user_sent_data(pespconn);
  38. }
  39.
  40. /******************************************************************************
  41. * FunctionName : user_tcp_recon_cb
  42. * Description  : reconnect callback, error occured in TCP connection.
  43. * Parameters   : arg -- Additional argument to pass to the callback function
  44. * Returns      : none
  45. *******************************************************************************/
  46. LOCAL void ICACHE_FLASH_ATTR
  47. user_tcp_recon_cb(void *arg, sint8 err)
  48. {
  49.    //error occured , tcp connection broke. user can try to reconnect here.
  50.
  51.     os_printf("reconnect callback, error code %d !!! \r\n",err);
  52. }
 楼主| cowboy2014 发表于 2016-11-20 20:29 | 显示全部楼层
  2. * FunctionName : user_dns_found
  3. * Description  : dns found callback
  4. * Parameters   : name -- pointer to the name that was looked up.
  5. *                ipaddr -- pointer to an ip_addr_t containing the IP address of
  6. *                the hostname, or NULL if the name could not be found (or on any
  7. *                other error).
  8. *                callback_arg -- a user-specified callback argument passed to
  9. *                dns_gethostbyname
  10. * Returns      : none
  11. *******************************************************************************/
  12. LOCAL void ICACHE_FLASH_ATTR
  13. user_dns_found(const char *name, ip_addr_t *ipaddr, void *arg)
  14. {
  15.     struct espconn *pespconn = (struct espconn *)arg;
  16.
  17.     if (ipaddr == NULL) {
  18.         os_printf("user_dns_found NULL \r\n");
  19.         return;
  20.     }
  21.
  22.     //dns got ip
  23.     os_printf("user_dns_found %d.%d.%d.%d \r\n",
  24.             *((uint8 *)&ipaddr->addr), *((uint8 *)&ipaddr->addr + 1),
  25.             *((uint8 *)&ipaddr->addr + 2), *((uint8 *)&ipaddr->addr + 3));
  26.
  27.     if (tcp_server_ip.addr == 0 && ipaddr->addr != 0) {
  28.         // dns succeed, create tcp connection
  29.         os_timer_disarm(&test_timer);
  30.         tcp_server_ip.addr = ipaddr->addr;
  31.         os_memcpy(pespconn->proto.tcp->remote_ip, &ipaddr->addr, 4); // remote ip of tcp server which get by dns
  32.         pespconn->proto.tcp->remote_port = 80; // remote port of tcp server
  33.         pespconn->proto.tcp->local_port = espconn_port(); //local port of ESP8266
  34.
  35.         espconn_regist_connectcb(pespconn, user_tcp_connect_cb); // register connect callback
  36.         espconn_regist_reconcb(pespconn, user_tcp_recon_cb); // register reconnect callback as error handler
  37.
  38.         espconn_connect(pespconn); // tcp connect
  39.     }
  40. }
  41.
  42. /******************************************************************************
  43. * FunctionName : user_esp_platform_dns_check_cb
  44. * Description  : 1s time callback to check dns found
  45. * Parameters   : arg -- Additional argument to pass to the callback function
  46. * Returns      : none
  47. *******************************************************************************/
  48. LOCAL void ICACHE_FLASH_ATTR
  49. user_dns_check_cb(void *arg)
  50. {
  51.     struct espconn *pespconn = arg;
  52.
  53.     espconn_gethostbyname(pespconn, NET_DOMAIN, &tcp_server_ip, user_dns_found); // recall DNS function
  54.
  55.     os_printf("dns_check\n");
  56.     os_timer_arm(&test_timer, 1000, 0);
  57. }
  58.
  59. /******************************************************************************
  60. * FunctionName : CheckIpStart
  61. * Description  : set the router info which ESP8266 station will connect to
  62. * Parameters   : none
  63. * Returns      : none
  64. *******************************************************************************/
  65. void ICACHE_FLASH_ATTR
  66. CheckIpStart(void)
  67. {
  68.     // Connect to tcp server as NET_DOMAIN
  69.     user_tcp_conn.proto.tcp = &user_tcp;
  70.     user_tcp_conn.type = ESPCONN_TCP;
  71.     user_tcp_conn.state = ESPCONN_NONE;
  72.     tcp_server_ip.addr = 0;
  73.     espconn_gethostbyname(&user_tcp_conn, NET_DOMAIN, &tcp_server_ip, user_dns_found); // DNS function
  74.
  75.     os_timer_disarm(&test_timer);
  76.     os_timer_setfn(&test_timer, (os_timer_func_t *)user_dns_check_cb, user_tcp_conn);
  77.     os_timer_arm(&test_timer, 1000, 0);
  78. }
  79.
  80. void ICACHE_FLASH_ATTR
 楼主| cowboy2014 发表于 2016-11-20 20:31 | 显示全部楼层
  1. smartconfig_done(sc_status status, void *pdata)
  3.     switch(status) {
  4.         case SC_STATUS_WAIT:
  5.             os_printf("SC_STATUS_WAIT\n");
  6.             break;
  7.         case SC_STATUS_FIND_CHANNEL:
  8.             os_printf("SC_STATUS_FIND_CHANNEL\n");
  9.             break;
  10.         case SC_STATUS_GETTING_SSID_PSWD:
  11.             os_printf("SC_STATUS_GETTING_SSID_PSWD\n");
  12.             sc_type *type = pdata;
  13.             if (*type == SC_TYPE_ESPTOUCH) {
  14.                 os_printf("SC_TYPE:SC_TYPE_ESPTOUCH\n");
  15.             } else {
  16.                 os_printf("SC_TYPE:SC_TYPE_AIRKISS\n");
  17.             }
  18.             break;
  19.         case SC_STATUS_LINK:
  20.             os_printf("SC_STATUS_LINK\n");
  21.             struct station_config *sta_conf = pdata;
  22.
  23.             wifi_station_set_config(sta_conf);
  24.             wifi_station_disconnect();
  25.             wifi_station_connect();
  26.             break;
  27.         case SC_STATUS_LINK_OVER:
  28.             os_printf("SC_STATUS_LINK_OVER\n");
  29.             if (pdata != NULL) {
  30.                 uint8 phone_ip[4] = {0};
  31.
  32.                 os_memcpy(phone_ip, (uint8*)pdata, 4);
  33.                 os_printf("Phone ip: %d.%d.%d.%d\n",phone_ip[0],phone_ip[1],phone_ip[2],phone_ip[3]);
  34.                 CheckIpStart();
  35.             }
  36.             smartconfig_stop();
  37.             break;
  38.     }
  39.
  40. }
  41.
  42. void user_rf_pre_init(void)
  43. {
  44. }
  45.
  46. void user_init(void)
  47. {
  48.     os_printf("SDK version:%s\n", system_get_sdk_version());
  49.
  50.     wifi_set_opmode(STATION_MODE);
  51.     smartconfig_start(smartconfig_done);
  52. }
yiyigirl2014 发表于 2016-11-20 23:53 | 显示全部楼层
那个网站都打不开了。
deviceplugs 发表于 2016-11-21 10:51 | 显示全部楼层
APP或者微信是怎么开发的呢?
zhuotuzi 发表于 2016-11-21 20:19 | 显示全部楼层
专门做照明控制的?
稳稳の幸福 发表于 2016-11-22 18:39 | 显示全部楼层
学习了,原来跟服务器这么通信。
500days 发表于 2016-11-24 18:55 | 显示全部楼层
工具用的是什么,windows下可以开发吗
