[DemoCode下载] mini51的定时器延时
 楼主| huangcunxiake 发表于 2017-3-28 23:06 | 显示全部楼层 |阅读模式
  1. /******************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * $Revision: 6 $
  5. * $Date: 15/10/06 1:25p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate the usage of TIMER_Delay() API to generate a 1 second delay
  7. *
  8. * @note
  9. * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
  10. *****************************************************************************/
  11. #include <stdio.h>
  12. #include "Mini51Series.h"
  13. void SYS_Init(void)
  14. {
  15.     /*---------------------------------------------------------------------------------------------------------*/
  16.     /* Init System Clock        */
  17.     /*---------------------------------------------------------------------------------------------------------*/
  18.     /* Unlock protected registers */
  19.     SYS_UnlockReg();
  20.     /* Set P5 multi-function pins for XTAL1 and XTAL2 */
  21.     SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
  22.     SYS->P5_MFP |= (SYS_MFP_P50_XTAL1 | SYS_MFP_P51_XTAL2);
  23.     /* Enable external 12MHz XTAL (UART), and internal 22.1184MHz */
  24.     CLK->PWRCON = CLK_PWRCON_XTL12M | CLK_PWRCON_IRC22M_EN_Msk;
  25.     /* Waiting for clock ready */
  26.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL_STB_Msk | CLK_CLKSTATUS_IRC22M_STB_Msk);
  27.     /* Enable UART and Timer 0 clock */
  28.     CLK->APBCLK = CLK_APBCLK_UART_EN_Msk | CLK_APBCLK_TMR0_EN_Msk;
  29.     /* Select UART clock source from external crystal*/
  30.     CLK->CLKSEL1 = (CLK->CLKSEL1 & ~CLK_CLKSEL1_UART_S_Msk) | CLK_CLKSEL1_UART_S_XTAL;
  31.     /* Update System Core Clock */
  32.     /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CycylesPerUs automatically. */
  33.     SystemCoreClockUpdate();
  34.     /*---------------------------------------------------------------------------------------------------------*/
  35.     /* Init I/O Multi-function        */
  36.     /*---------------------------------------------------------------------------------------------------------*/
  37.     /* Set P1 multi-function pins for UART RXD, TXD */
  38.     SYS->P0_MFP = SYS_MFP_P00_TXD | SYS_MFP_P01_RXD;
  39.     /* Lock protected registers */
  40.     SYS_LockReg();
  41. }
  42. int main(void)
  43. {
  44.     /* Init System, IP clock and multi-function I/O
  45.        In the end of SYS_Init() will issue SYS_LockReg()
  46.        to lock protected register. If user want to write
  47.        protected register, please issue SYS_UnlockReg()
  48.        to unlock protected register if necessary */
  49.     SYS_Init();
  50.     /* Init UART to 115200-8n1 for print message */
  51.     UART_Open(UART, 115200);
  52.     printf("\nThis sample code use timer to create a small delay \n");
  53.     while(1) {
  54.         printf("Delay 1 second\n");
  55.         TIMER_Delay(TIMER0, 1000000);
  56.     }
  57. }
  58. /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
 楼主| huangcunxiake 发表于 2017-3-28 23:07 | 显示全部楼层
仔细观察,新唐的ARM CM0系列的库函数都是一样一样的,很容易移植。
稳稳の幸福 发表于 2017-3-29 09:30 | 显示全部楼层
新唐的库函数移植能力还是很强的。
myxiaonia 发表于 2017-3-29 15:00 | 显示全部楼层
请问哪里有便宜的mini51系列开发板
dongnanxibei 发表于 2017-3-29 19:15 | 显示全部楼层
时钟是一个复杂的内容,常用的可以直接弄好几个函数,直接用。
643757107 发表于 2017-3-29 19:45 | 显示全部楼层
TIMER_Delay(TIMER0, 1000000);这个函数单位应该是uS
 楼主| huangcunxiake 发表于 2017-4-6 18:48 | 显示全部楼层
另外要考虑到计时的长度问题,不是单纯的加上就行的,比如总的计数长度是100,现在95了,你计数的值超过5了怎么处理,都要考虑到的。
yiyigirl2014 发表于 2017-4-6 21:38 | 显示全部楼层
在那个函数里已经考虑到了那个越界的情况。
