REG_Addr在哪呢
 楼主| juventus9554 发表于 2011-2-27 10:52 | 显示全部楼层 |阅读模式
ADDR, ST, I2c, TE, ui
uint8 I2C_MasterWriteBuf(uint8 slaveAddr, uint8 * xferData, uint8 cnt,uint8 mode)
    uint8 tmr;
    uint8 errStatus = I2C_MSTR_NO_ERROR;
    /* Determine whether or not to automatically generate a stop condition */
    if(mode & I2C_MODE_NO_STOP)
       /* Do not generate a Stop at the end of transfer */
       I2C_mstrControl |= I2C_MSTR_NO_STOP;
    else  /* Generate a Stop */
       I2C_mstrControl &= ~I2C_MSTR_NO_STOP;
    if((I2C_State == I2C_SM_IDLE) || (I2C_State == I2C_SM_MSTR_HALT))
        errStatus = I2C_MSTR_BUS_TIMEOUT;
        if(I2C_State != I2C_SM_MSTR_HALT)
            for(tmr = I2C_MSTR_TIMEOUT; tmr > 0; tmr--)
                if((I2C_MCSR & I2C_MCSR_BUS_BUSY) == 0)
                   break;
                CyDelay(1);    /* Wait 1 mSec */
        else   /* Bus halted waiting for restart */
            I2C_mstrStatus &= ~I2C_MSTAT_XFER_HALT;
            CyIntClearPending(I2C_ISR_NUMBER);
        /* If no timeout error, generate start */
        if(errStatus == I2C_MSTR_NO_ERROR)
            slaveAddr = (slaveAddr << 1);
            I2C_State = I2C_SM_MSTR_WR_ADDR;
            I2C_mstrWrBufPtr   = xferData; /* Set buffer pointer */
            I2C_mstrWrBufIndex = 0u;       /* Start buffer at zero */
            I2C_mstrWrBufSize  = cnt;      /* Set buffer size */
            I2C_DATA = slaveAddr;            /* Write address to data reg */
            /* Generate a Start or ReStart depending on flag passed */
            if(mode & I2C_MODE_REPEAT_START)
                I2C_MCSR = I2C_MCSR_RESTART_GEN;  /* Generate a ReStart */
            else
                I2C_MCSR = I2C_MCSR_START_GEN;  /* Generate a Start */
            CyIntEnable(I2C_ISR_NUMBER);   /* IRQ must be enabled for this to work */
            /* Clear write complete flag */
            I2C_mstrStatus &= ~I2C_MSTAT_WR_CMPLT;
    else
       errStatus = I2C_MSTR_SLAVE_BUSY;
    return(errStatus);
在I2C的主模式下,只有一个Slave地址,还一个REG_Addr在哪呢?
 楼主| juventus9554 发表于 2011-2-27 10:58 | 显示全部楼层
这个是函数的功能!!
* Function Name: I2C_MasterWriteBuf
* Summary:
*  This function initiates a write transaction with an addressed slave.  Writes
*  one or more bytes (cnt) to the slave I2C device and gets the data from RAM
*  or ROM array pointed to by the array pointer.  Once this routine is called,
*  the included ISR will handle further data in byte by byte mode.
* Parameters:
*  slaveAddr: 7-bit slave address
*  xferData:  Pointer to data in array.
*  cnt:       Count of data to write.
*  mode:      Mode of operation.  It defines normal start, restart,
*             stop, no-stop, etc.
* Return:
*  void
* Theory:
* Side Effects:
*  //:TODO  incorporate mode
小小猫咪 发表于 2011-2-27 11:15 | 显示全部楼层
搂主找I2C register address 做什么哪,在TRM可以找到 http://www.cypress.com/?rID=37833
 楼主| juventus9554 发表于 2011-2-27 11:27 | 显示全部楼层
我现在要挂一个I2C的器件上去
houcs 发表于 2011-2-27 11:33 | 显示全部楼层
楼主是想知道程序有问题么?
 楼主| juventus9554 发表于 2011-2-27 11:40 | 显示全部楼层
是啊,还有就是器件地址0x03寄存器地址0x20.怎么弄?
jxin 发表于 2011-2-27 11:53 | 显示全部楼层
你是说I2CMaster的REG_Addr? 这个可以参照I2C user moudle Datasheet 和PSoC® 3 Registers TRM
jxin 发表于 2011-3-5 12:11 | 显示全部楼层
这个是自己定义的,参照psoc creator > file > open > example project > EzI2Cdesign
