[应用相关] maple / arduino ds1302驱动库和例程
 楼主| Brand2 发表于 2017-9-26 18:49 | 显示全部楼层 |阅读模式
例程(库中自带的)
Example sketch for interfacing with the DS1302 timekeeping chip.
Copyright (c) 2009, Matt Sparks
All rights reserved.
http://quadpoint.org/projects/arduino-ds1302
#include <stdio.h>
#include <string.h>
#include <DS1302.h>
/* Set the appropriate digital I/O pin connections */
unsigned int CE_PIN   = 3;
unsigned int IO_PIN   = 4;
unsigned int SCLK_PIN = 5;
/* Create buffers */
char buf[50];
char day[10];
/* Create a DS1302 object */
DS1302 rtc(CE_PIN, IO_PIN, SCLK_PIN);
void print_time()
  /* Get the current time and date from the chip */
  Time t = rtc.time();
  /* Name the day of the week */
  memset(day, 0, sizeof(day));  /* clear day buffer */
  switch (t.day) {
    case 1:
      strcpy(day, "Sunday");
      break;
    case 2:
      strcpy(day, "Monday");
      break;
    case 3:
      strcpy(day, "Tuesday");
      break;
    case 4:
      strcpy(day, "Wednesday");
      break;
    case 5:
      strcpy(day, "Thursday");
      break;
    case 6:
      strcpy(day, "Friday");
      break;
    case 7:
      strcpy(day, "Saturday");
      break;
  /* Format the time and date and insert into the temporary buffer */
  snprintf(buf, sizeof(buf), "%s %04d-%02d-%02d %02d:%02d:%02d",
           day,
           t.yr, t.mon, t.date,
           t.hr, t.min, t.sec);
  /* Print the formatted string to serial so we can see the time */
  SerialUSB.println(buf);
void setup()
  /* Initialize a new chip by turning off write protection and clearing the
     clock halt flag. These methods needn't always be called. See the DS1302
     datasheet for details. */
  rtc.write_protect(false);
  rtc.halt(false);
  /* Make a new time object to set the date and time */
  /*   Tuesday, May 19, 2009 at 21:16:37.            */
  Time t(2009, 5, 19, 21, 16, 37, 3);
  /* Set the time and date on the chip */
  rtc.time(t);
/* Loop and print the time every second */
void loop()
  print_time();
  delay(1000);
