DM6437新手求助,disable vpss disable edma
 楼主| lingbaohe 发表于 2011-7-15 10:25 | 显示全部楼层 |阅读模式
如题,毕业设计做视频压缩解压缩,刚开始学DM6437,先试了DM6437-A所带的例程,本来可以程序都运行
后来出现了这样的问题
编译能通过,但是load *.out文件时,无法加载进去
可以看到这样的信息
EVMDM6437 Startup Sequence
Setup Cache (L1P = 32K) + (L1D = 32K) + (L2 = ALL SRAM)... [Done]
Setup PinMux... (Normal operation)... [Done]
Setup Power Modules (All on)... [Done]
Setup PLL1 (Powering up PLL)... (DSP = 594 MHz + SYSCLK2 = 198 MHz + SYSCLK3 = 99 MHz + Onchip Oscillator)... [Done]
Setup PLL2 (Powering up PLL)... (VPSS = 54 MHz + DDR2 Phy = 162 MHz + Onchip Oscillator)... [Done]
Setup DDR2 (162 MHz + 32-bit bus)... [Done]
Setup EMIF CS2 - NOR Flash (8-bit bus)... [Done]
Startup Complete.
Disable VPSS
Clear L2 Cache in DDR Range
Disable EDMA events
Disable EDMA events
我将CCS3.3重装了之后还是不行
各位,拜托,求个解决方案
