[UNO] AD8232心率脉搏传感器的arduino程序
 楼主| 初学者MCU 发表于 2018-5-7 22:16 | 显示全部楼层 |阅读模式
各位大佬,请问AD8232心率脉搏传感器的arduino程序怎么写呀
dirtwillfly 发表于 2018-5-8 08:30 | 显示全部楼层
cos12a 发表于 2018-5-23 12:28 | 显示全部楼层
Heart_Rate_Display.ino
Demo Program for AD8232 Heart Rate sensor.
Casey Kuhns @ SparkFun Electronics
6/27/2014
https://github.com/sparkfun/AD8232_Heart_Rate_Monitor
The AD8232 Heart Rate sensor is a low cost EKG/ECG sensor.  This example shows
how to create an ECG with real time display.  The display is using Processing.
This sketch is based heavily on the Graphing Tutorial provided in the Arduino
IDE. http://www.arduino.cc/en/Tutorial/Graph
Resources:
This program requires a Processing sketch to view the data in real time.
Development environment specifics:
        IDE: Arduino 1.0.5
        Hardware Platform: Arduino Pro 3.3V/8MHz
        AD8232 Heart Monitor Version: 1.0
This code is beerware. If you see me (or any other SparkFun employee) at the
local pub, and you've found our code helpful, please buy us a round!
Distributed as-is; no warranty is given.
void setup() {
  // initialize the serial communication:
  Serial.begin(9600);
  pinMode(10, INPUT); // Setup for leads off detection LO +
  pinMode(11, INPUT); // Setup for leads off detection LO -
void loop() {
  if((digitalRead(10) == 1)||(digitalRead(11) == 1)){
    Serial.println('!');
  else{
    // send the value of analog input 0:
      Serial.println(analogRead(A0));
  //Wait for a bit to keep serial data from saturating
  delay(20);
请问怎样把数据导出啊  发表于 2020-3-24 12:12
chenguang1234 发表于 2020-1-1 17:44 | 显示全部楼层
挺好的
旧铁皮石斛 发表于 2020-3-24 12:11 | 显示全部楼层
你好,请问你们会不会把数据导出或者成表格
lioncity 发表于 2020-9-5 20:34 | 显示全部楼层
谢谢分享
