[VHDL] 程序求大神注释
 楼主| 晨末世今 发表于 2018-5-24 10:59 | 显示全部楼层 |阅读模式
library IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL ;
ENTITY keys_lock IS
        PORT (
        clk ,clr,status  : IN   STD_LOGIC ;
           selout    : OUT  STD_LOGIC_VECTOR (2 downto 0) ;
        key       : IN   STD_LOGIC_VECTOR (3 downto 0) ;
        segout    : OUT STD_LOGIC_VECTOR (0  TO 6);
    locks,unlocks: OUT STD_LOGIC
END keys_lock ;
ARCHITECTURE doit of keys_lock IS
signal counter1 : std_logic_vector(1 downto 0);
signal counter : std_logic_vector(2 downto 0);
signal counter2 : std_logic_vector(4 downto 0);
signal dc0,dc1,dc2,dc3,lock0,lock1,lock2,lock3 : std_logic_vector(3 downto 0);
signal dcc1 : std_logic_vector(4 downto 0);
signal dcc : std_logic_vector(6 downto 0);
signal d0,d1,d2,d3 : std_logic_vector(0 to 6);
signal clk1,test,koff: std_logic;
component decode
  PORT(
    ssin : in  std_logic_vector(3 downto 0);
    ssout: out std_logic_vector(0 to 6)
end component;
begin
test<=key(3) and key(2) and key(1) and key(0);
P1: process(clr,clk)
begin
   if(clr='0') then
     counter1<="00";
   elsif(clk'event and clk='1') then
     counter1<=counter1+1;
   end if;
end process P1;
clk1<='0' when counter1<="01" else
      '1';
P2: process(clr,clk1,test)
begin
   if(clr='0') then
     counter<="000";
   elsif(clk1'event and clk1='1') then
     if(test='0') or (koff='0') then
       counter<=counter;
     else
       counter<=counter+1;
     end if;
   end if;
end process P2;
selout<=counter;
dcc<=counter & key;
P3: process(clk,test)
begin
   if(clk'event and clk='0') then
     if(dcc="0001110") then
        dcc1<="00000";
     elsif(dcc="0011110") then
        dcc1<="00001";
     elsif(dcc="0101110") then
        dcc1<="00010";
     elsif(dcc="0111110") then
        dcc1<="00011";
     elsif(dcc="1101110") then
        dcc1<="00100";
     elsif(dcc="1111110") then
        dcc1<="00101";
     elsif(dcc="0001101") then
        dcc1<="00110";
     elsif(dcc="0011101") then
        dcc1<="00111";
     elsif(dcc="1001101") then
        dcc1<="01000";
     elsif(dcc="1011101") then
        dcc1<="01001";
     elsif(dcc="1101101") then
        dcc1<="01010";
     elsif(dcc="1111101") then
        dcc1<="01011";
     elsif(dcc="0101011") then
        dcc1<="01100";
     elsif(dcc="0111011") then
        dcc1<="01101";
     elsif(dcc="1001011") then
        dcc1<="01110";
     elsif(dcc="1011011") then
        dcc1<="01111";
     elsif(dcc="1001110") then
        dcc1<="10000";
     elsif(dcc="1011110") then
        dcc1<="10001";
     elsif(test='0') then
        dcc1<="01111";
     end if;
   end if;
end process P3;
--dcc1<="0000" when (dcc="0001110") else
--      "0001" when (dcc="0011110") else
--      "0010" when (dcc="0101110") else
--      "0011" when (dcc="0111110") else
--      "0100" when (dcc="1101110") else
--      "0101" when (dcc="1111110") else
--      "0110" when (dcc="0001101") else
--      "0111" when (dcc="0011101") else
--      "1000" when (dcc="1001101") else
--      "1001" when (dcc="1011101") else
--     "1010" when (dcc="1101101") else
--      "1011" when (dcc="1111101") else
--      "1100" when (dcc="0101011") else
--      "1101" when (dcc="0111011") else
--      "1110" when (dcc="1001011") else
--      "1111" when (dcc="1011011") else
--      "0000";
P4: process(test,clk,clr)
begin
   if(clr='0') then
     counter2<="00000";
     koff<='1';
     if(test='0') then
        counter2<="00000";
        koff<='0';
     elsif(counter2<"11110") then
        counter2<=counter2+1;
    -- end if;
     elsif(counter2="11110") then
       koff<='1';
     end if;
    end if;
end process P4;
--koff<='0' when counter2<="01110"  else
--      '1';
P5: process(koff,clr)
begin
   if(clr='0') then
      dc0<="0000";
      dc1<="0000";
      dc2<="0000";
      dc3<="0000";
      locks<='0';
      unlocks<='0';
   elsif(koff'event and koff='1') then
    if(dcc1="10000" and status='0') then
      lock0<=dc0;
      lock1<=dc1;
      lock2<=dc2;
      lock3<=dc3;
      locks<='1';
      unlocks<='0';
    elsif(dcc1="10001" and status='1') then
      if(dc0=lock0 and dc1=lock1 and dc2=lock2 and dc3=lock3) then
        locks<='0';
        unlocks<='1';
      end if;
    else
      dc0<=dcc1(3 downto 0);
      dc1<=dc0;
      dc2<=dc1;
      dc3<=dc2;
   end if;
  end if;
end process P5;
U1: decode port map(ssin=>dc0, ssout=>d0);
U2: decode port map(ssin=>dc1, ssout=>d1);
U3: decode port map(ssin=>dc2, ssout=>d2);
U4: decode port map(ssin=>dc3, ssout=>d3);
segout<=d0 when counter="000" else
        d1 when counter="001" else
        d2 when counter="010" else
        d3 when counter="011" else
        "0000000";
end doit;
LIBRARY IEEE;
ENTITY decode IS
PORT(
end decode;
ARCHITECTURE a of decode IS
begin
  ssout<="1111110" when ssin="0000" else
             "0110000" when ssin="0001" else
                    "1101101" when ssin="0010" else
             "1111001" when ssin="0011" else
             "0110011" when ssin="0100" else
             "1011011" when ssin="0101" else
             "1011111" when ssin="0110" else
             "1110000" when ssin="0111" else
             "1111111" when ssin="1000" else
             "1111011" when ssin="1001" else
             "1110111" when ssin="1010" else
             "0011111" when ssin="1011" else
             "1001110" when ssin="1100" else
             "0111101" when ssin="1101" else
             "1001111" when ssin="1110" else
             "1000111" when ssin="1111" else
                 "0000000";
end a;
feihufuture 发表于 2018-5-24 11:17 | 显示全部楼层
貌似能看懂,但可惜自己不是大神!
可以帮忙注释下吗?  发表于 2018-5-24 16:14
Cjy_JDxy 发表于 2018-5-24 14:47 | 显示全部楼层
我只知道是VHDL
zhangmangui 发表于 2018-5-24 23:08 | 显示全部楼层
工程中很少用VHDL     只有大学的基础了
panjunren 发表于 2021-12-10 16:45 | 显示全部楼层
工程中很少用VHDL     只有大学的基础了
好像是数码管显示~~~
