FATFS文件系统的SD卡移植
633|0
 楼主| 没名字的人 发表于 2020-4-23 07:07 | 显示全部楼层 |阅读模式
FATFS文件系统的底层接口,disk_write中添加SD卡扇区写操作时为什么没有像spi flash移植FATFS那样先进行擦除操作???
spi flash的disk_write
DRESULT TM_FATFS_FLASH_SPI_disk_write(BYTE *buff, DWORD sector, UINT count)
        uint32_t write_addr;
        FLASH_DEBUG_FUNC();
        sector+=512;
        write_addr = sector<<12;
        SPI_FLASH_SectorErase(write_addr);//进行擦除
        SPI_FLASH_BufferWrite(buff,write_addr,4096);
        return RES_OK;
SD的disk_write
DRESULT TM_FATFS_SD_SDIO_disk_write(BYTE *buff, DWORD sector, UINT count)
        SD_Error Status = SD_OK;
        if (!TM_FATFS_SDIO_WriteEnabled()) {
                return RES_WRPRT;
        if (SD_Detect() != SD_PRESENT) {
                return RES_NOTRDY;
        if ((DWORD)buff & 3) {
                DRESULT res = RES_OK;
                DWORD scratch[BLOCK_SIZE / 4];
                while (count--) {
                        memcpy(scratch, buff, BLOCK_SIZE);
                        res = TM_FATFS_SD_SDIO_disk_write((void *)scratch, sector++, 1);
                        if (res != RES_OK) {
                                break;
                        buff += BLOCK_SIZE;
                return(res);
        Status = SD_WriteMultiBlocks((uint8_t *)buff, (uint64_t)sector << 9, BLOCK_SIZE, count); // 4GB Compliant
        if (Status == SD_OK) {
                SDTransferState State;
                Status = SD_WaitWriteOperation(); // Check if the Transfer is finished
                while ((State = SD_GetStatus()) == SD_TRANSFER_BUSY); // BUSY, OK (DONE), ERROR (FAIL)
                if ((State == SD_TRANSFER_ERROR) || (Status != SD_OK)) {
                        return RES_ERROR;
                } else {
                        return RES_OK;
        } else {
                return RES_ERROR;
