stm32f042f4p6做USBHID遇到问题无法接收PC数据,枚举成功,invaild command
 楼主| lvface123654 发表于 2020-5-7 21:26 | 显示全部楼层 |阅读模式
小弟之前没搞过USBHID,现在用STM32F042F4的USBhid,然后用stm32cube自动生成一个可以自由收发的64字节的设备,设备可以正常枚举,但是发现一个奇怪问题,就是设备接收pc数据时,只有设备在while循环里发送数据,才能收到上位机的数据,不然USB HOUND总是报invaild command。以下为描述符
__ALIGN_BEGIN static uint8_t CUSTOM_HID_ReportDesc_FS[USBD_CUSTOM_HID_REPORT_DESC_SIZE] __ALIGN_END =
  /* USER CODE BEGIN 0 */
0x06, 0xFF, 0x00,      /* USAGE_PAGE (Vendor Page: 0xFF00) */
0x09, 0x01,            /* USAGE (Demo Kit)               */
0xa1, 0x01, /* COLLECTION (Application) */
0x09,0x03, // USAGE ID - Vendor defined
0x15,0x00, // LOGICAL_MINIMUM (0)
0x26,0x00, 0xFF, // LOGICAL_MAXIMUM (255)
0x75,0x08, // REPORT_SIZE (8)
0x95,64, // REPORT_COUNT :SendLength
0x81,0x02, // INPUT (Data,Var,Abs)
0x09,0x04, // USAGE ID - Vendor defined
0x26,0x00,0xFF, // LOGICAL_MAXIMUM (255)
0x95,64, // REPORT_COUNT:ReceiveLength
0x91,0x02, // OUTPUT (Data,Var,Abs)
  0xC0    /*     END_COLLECTION                     */
__ALIGN_BEGIN static uint8_t USBD_CUSTOM_HID_CfgDesc[USB_CUSTOM_HID_CONFIG_DESC_SIZ] __ALIGN_END =
  0x09, /* bLength: Configuration Descriptor size */
  USB_DESC_TYPE_CONFIGURATION, /* bDescriptorType: Configuration */
  USB_CUSTOM_HID_CONFIG_DESC_SIZ,
  /* wTotalLength: Bytes returned */
  0x00,
  0x01,         /*bNumInterfaces: 1 interface*/
  0x01,         /*bConfigurationValue: Configuration value*/
  0x00,         /*iConfiguration: Index of string descriptor describing
  the configuration*/
  0xA0,//0xC0,         /*bmAttributes: bus powered */
  0xC8,         /*MaxPower 100 mA: this current is used for detecting Vbus*/
  /************** Descriptor of CUSTOM HID interface ****************/
  /* 09 */
  0x09,         /*bLength: Interface Descriptor size*/
  USB_DESC_TYPE_INTERFACE,/*bDescriptorType: Interface descriptor type*/
  0x00,         /*bInterfaceNumber: Number of Interface*/
  0x00,         /*bAlternateSetting: Alternate setting*/
  0x02,         /*bNumEndpoints*/
  0x03,         /*bInterfaceClass: CUSTOM_HID*/
  0x00,         /*bInterfaceSubClass : 1=BOOT, 0=no boot*/
  0x00,         /*nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse*/
  0,            /*iInterface: Index of string descriptor*/
  /******************** Descriptor of CUSTOM_HID *************************/
  /* 18 */
  0x09,         /*bLength: CUSTOM_HID Descriptor size*/
  CUSTOM_HID_DESCRIPTOR_TYPE, /*bDescriptorType: CUSTOM_HID*/
  0x11,         /*bCUSTOM_HIDUSTOM_HID: CUSTOM_HID Class Spec release number*/
  0x01,
  0x00,         /*bCountryCode: Hardware target country*/
  0x01,         /*bNumDescriptors: Number of CUSTOM_HID class descriptors to follow*/
  0x22,         /*bDescriptorType*/
  USBD_CUSTOM_HID_REPORT_DESC_SIZE,/*wItemLength: Total length of Report descriptor*/
  0x00,
  /******************** Descriptor of Custom HID endpoints ********************/
  /* 27 */
  0x07,          /*bLength: Endpoint Descriptor size*/
  USB_DESC_TYPE_ENDPOINT, /*bDescriptorType:*/
  CUSTOM_HID_EPIN_ADDR,     /*bEndpointAddress: Endpoint Address (IN)*/
  0x03,          /*bmAttributes: Interrupt endpoint*/
  CUSTOM_HID_EPIN_SIZE, /*wMaxPacketSize: 2 Byte max */
  0x00,
  0x05,          /*bInterval: Polling Interval (20 ms)*/
  /* 34 */
  0x07,                 /* bLength: Endpoint Descriptor size */
  USB_DESC_TYPE_ENDPOINT,        /* bDescriptorType: */
  CUSTOM_HID_EPOUT_ADDR,  /*bEndpointAddress: Endpoint Address (OUT)*/
  0x03,        /* bmAttributes: Interrupt endpoint */
  CUSTOM_HID_EPOUT_SIZE,        /* wMaxPacketSize: 2 Bytes max  */
  0x00,
  0x05,        /* bInterval: Polling Interval (20 ms) */
  /* 41 */
 楼主| lvface123654 发表于 2020-5-8 15:38 | 显示全部楼层
今天抽时间看了USBhid协议,恍然大悟,结帖,问题解决了,设备描述符问题
