[DemoCode下载] N76E003是可以读取UID的非常棒
 楼主| zhuomuniao110 发表于 2020-6-20 23:35 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Nuvoton Technoledge Corp.
  8. //  Website: http://www.nuvoton.com
  9. //  E-Mail : MicroC-8bit@nuvoton.com
  10. //  Date   : Apr/21/2017
  11. //***********************************************************************************************************
  12. //***********************************************************************************************************
  13. //  File Function: N76E003 Read actual bandgap value by IAP command
  14. //***********************************************************************************************************
  15. #include "N76E003.h"
  16. #include "Common.h"
  17. #include "Delay.h"
  18. #include "SFR_Macro.h"
  19. #include "Function_define.h"
  20. UINT8 UID_BYTE(UINT8 Addr)
  21. {
  22.                 UINT8 DATATEMP;
  23.                 set_IAPEN;
  24.                 IAPAL = Addr;
  25.     IAPAH = 0x00;
  26.     IAPCN = READ_UID;
  27.     set_IAPGO;
  28.                 DATATEMP = IAPFD;
  29.                 clr_IAPEN;
  30.                 return DATATEMP;
  31. }
  32. void main(void)
  33. {
  34.         UINT8 READ1,READ2;
  35.         Set_All_GPIO_Quasi_Mode;
  36.         InitialUART0_Timer3(115200);
  37.
  38. //---------toggle GPIO1---------
  39.         clr_GPIO1;
  40.         Timer0_Delay1ms(100);
  41.         set_GPIO1;
  42.         Timer0_Delay1ms(100);
  43.         clr_GPIO1;
  44.         Timer0_Delay1ms(100);
  45.         set_GPIO1;
  46.         Timer0_Delay1ms(100);
  47. //---------end toggle GPIO1---------
  48.
  49.         READ1 = UID_BYTE(0x02);
  50.         READ2 = UID_BYTE(0x05);
  51.
  52.         while(1)
  53.         {
  54. //                        printf ("\n Value = 0x%bx",READ1);
  55.         }
  56. }
 楼主| zhuomuniao110 发表于 2020-6-20 23:37 | 显示全部楼层
出厂前,每颗 N76E003都会预烧一个96位的序列号,用以确保该芯片的唯一性,这个唯一代码被称为序列号UID (Unique Code)。用户获得序列号的唯一方式是通过IAP指令读取,详见 IAP 命令.
dongnanxibei 发表于 2020-6-21 11:43 | 显示全部楼层
UICD与UID区别是?
xuanhuanzi 发表于 2020-6-21 11:58 | 显示全部楼层
我要对比一下。
xinpian101 发表于 2020-6-21 14:57 | 显示全部楼层
这个是真的非常有用。
antusheng 发表于 2020-6-22 12:58 | 显示全部楼层
UID与UCID在内存里面是连续存储的吗
晓伍 发表于 2020-7-10 17:08 | 显示全部楼层
非常感谢楼主分享
玛尼玛尼哄 发表于 2020-7-11 18:53 | 显示全部楼层
一直没想明白具体怎么用。
imdx 发表于 2020-8-29 10:12 | 显示全部楼层
为什么我的芯片UID读出来全部是0?
