[学习资料] linux内核配置pic32,Linux内核 sysctl.conf 解释
 楼主| gwsan 发表于 2021-8-10 15:45 | 显示全部楼层 |阅读模式
可以通过/etc/sysctl.conf控制和配置Linux内核及网络设置。
# 避免放大攻击
net.ipv4.icmp_echo_ignore_broadcasts = 1
# 开启恶意icmp错误消息保护
net.ipv4.icmp_ignore_bogus_error_responses = 1
# 开启SYN洪水攻击保护
net.ipv4.tcp_syncookies = 1
# 开启并记录欺骗,源路由和重定向包
net.ipv4.conf.all.log_martians = 1
net.ipv4.conf.default.log_martians = 1
# 处理无源路由的包
net.ipv4.conf.all.accept_source_route = 0
net.ipv4.conf.default.accept_source_route = 0
# 开启反向路径过滤
net.ipv4.conf.all.rp_filter = 1
net.ipv4.conf.default.rp_filter = 1
# 确保无人能修改路由表
net.ipv4.conf.all.accept_redirects = 0
net.ipv4.conf.default.accept_redirects = 0
net.ipv4.conf.all.secure_redirects = 0
net.ipv4.conf.default.secure_redirects = 0
# 不充当路由器
net.ipv4.ip_forward = 0
net.ipv4.conf.all.send_redirects = 0
net.ipv4.conf.default.send_redirects = 0
# 开启execshild
kernel.exec-shield = 1
kernel.randomize_va_space = 1
# IPv6设置
net.ipv6.conf.default.router_solicitations = 0
net.ipv6.conf.default.accept_ra_rtr_pref = 0
net.ipv6.conf.default.accept_ra_pinfo = 0
net.ipv6.conf.default.accept_ra_defrtr = 0
net.ipv6.conf.default.autoconf = 0
net.ipv6.conf.default.dad_transmits = 0
net.ipv6.conf.default.max_addresses = 1
# 优化LB使用的端口
# 增加系统文件描述符限制
fs.file-max = 65535
# 允许更多的PIDs (减少滚动翻转问题); may break some programs 32768
kernel.pid_max = 65536
# 增加系统IP端口限制
net.ipv4.ip_local_port_range = 2000 65000
# 增加TCP最大缓冲区大小
net.ipv4.tcp_rmem = 4096 87380 8388608
net.ipv4.tcp_wmem = 4096 87380 8388608
# 增加Linux自动调整TCP缓冲区限制
# 最小,默认和最大可使用的字节数
# 最大值不低于4MB,如果你使用非常高的BDP路径可以设置得更高
# Tcp窗口等
net.core.rmem_max = 8388608
net.core.wmem_max = 8388608
net.core.netdev_max_backlog = 5000
net.ipv4.tcp_window_scaling = 1
