51AD 采样正弦波是一条直线!频率不对?
 楼主| qqfishboy 发表于 2012-3-19 11:03 | 显示全部楼层 |阅读模式
上次问的问题 关于 f350的采样慢的问题 解决了~ 谢谢ayb_ice等几位大神~跟输出字的速度也有关系 最近又遇到了新问题
正弦波的周期是20ms!我想把他采样下来,显示波形。但是不管我如何设置采样周期 始终是一条直线~最奇怪的是 ad输入引脚 如果接电压用滑动变阻器调节  采样的ad或者电压是对的。这是什么原因呢  ???
部分程序
#define MDCLK        128000            // Modulator Clock (Hz)
int ADC_Buffered(void)
    unsigned int i, Sampling_times=1000;
  float average;
         for (i = 0; i < Sampling_times; i++)
          while(!AD0INT);
         AD0INT = 0;
    ADC_OutputVal = ADC0H;
          ADC_OutputVal =ADC_OutputVal<< 16;
          ADC_OutputVal += (long)ADC0L + ((long)ADC0M << 8);
          sample_array = ADC_OutputVal;
     for(i=0;i<Sampling_times;i++)
     average=(float)sample_array;
    average=average/256/256/256;
    average=average*VREF;
    average=average*2;
    average=average;
    ADC_VIN= (int)average;
    Uart0_Send232(ADC_VIN);
    Uart0_SendString("\n");
ADC_VIN采样出的波形如下
void SYSCLK_Init (void)
     unsigned i;
     OSCICN = 0x80;                         // enable intosc
     CLKSEL = 0x00;                         // select intosc as sysclk source
// INTOSC configure
     OSCICN = 0x83;
// PLL configure
     CLKMUL = 0x00;                         // Reset Clock Multiplier
     CLKMUL &= ~0x03;                       // select INTOSC / 2 as PLL source
     CLKMUL |= 0x80;                        // Enable 4x Multipler (MULEN = 1)
     for (i = 0; i < 125; i++);             // Delay for at least 5us
     CLKMUL |= 0xC0;                        // Initialize Multiplier
     while (!(CLKMUL & 0x20));              // Poll for Multiply Ready
// SYSCLK configure
     VDM0CN = 0x80;                         // enable VDD monitor
     RSTSRC = 0x06;                         // enable missing clock detector
                                          // and VDD monitor reset sources
     CLKSEL = 0x02;                         // select PLL as clock source
// PORT_Init
// Configure the Crossbar and GPIO ports.
// P0.4 - TX0 (push-pull)
// P0.5 - RX0
void PORT7_Init (void)
     XBR0    |= 0x01;                       // UART0 Selected
     XBR1    |= 0x40;                       // Enable crossbar and weak pull-ups
     P0MDOUT |= 0xD0;                       // TX, LEDs = Push-pull
  P1MDOUT |= 0xFF;
// ADC0_Init extVREF Bipolar AIN0.1-AIN0.0
// This function initializes the ADC to measure across AIN0.1 and AIN0.0
// on the Target Board (Differential measurements, Bipolar codes)
void ADC0_Init (void)
     unsigned ADC0_decimation;
      REF0CN &= ~0x01;                       // disable internal vref
       // REF0CN |= 0x01;                        // (enable if using internal vref)
      // ADC0CN = 0x00;                         // unipolar output codes, GAIN=1
   ADC0CN = 0x10;                         // Bipolar output codes, GAIN=1
       //ADC0CF = 0x00;                         // interrupts upon SINC3 filter output
                                          // and uses internal VREF
       ADC0CF = 0x04;                         // interrupts upon SINC3 filter output
                                          // and ʹÓÃÍⲿVREF
       ADC0CLK = (SYSCLK/MDCLK)-1;       // Ideally, MDCLK = 2.4576 MHz
                                          // Generate MDCLK for modulator.
   // program decimation rate for desired OWR
     ADC0_decimation = (unsigned long) SYSCLK/ (unsigned long) OWR /
                     (unsigned long) (ADC0CLK+1)/(unsigned long)128;
     ADC0_decimation--;
       ADC0DEC = ADC0_decimation;
       ADC0BUF = 0x00;                        // ¹Ø±ÕÊäÈ뻺³å
     ADC0MUX = 0x0b;
                                          // AIN+ => AIN0.0
         ADC0DAC = 0x00;
         ADC0STA = 0x00;                                 // AIN- => AIN0.1
//   ADC0MUX = 0x08;
          ADC0MD |= 0x80;                      // ʹÄÜ(IDLE Mode)
 楼主| qqfishboy 发表于 2012-3-19 11:05 | 显示全部楼层
感觉像是平均值来着 ~滤波器没设置对吗????
coody 发表于 2012-3-19 17:40 | 显示全部楼层
除非你采样的周期跟正弦波的周期严格相等。
liuyuxiier 发表于 2012-3-19 22:33 | 显示全部楼层
好好查看下硬件,是不是你的正弦信号根本就没接上去!用示波器看AD输入引脚有没有信号
g1234567 发表于 2012-3-20 12:37 | 显示全部楼层
SYSCLK?
 楼主| qqfishboy 发表于 2012-3-22 19:12 | 显示全部楼层
呵呵 知道怎么回事了  这个采样频率太低了
呵呵
