cadence:capture生成allegro网表的一个问题
 楼主| 21hanyuan 发表于 2012-5-2 14:43 | 显示全部楼层 |阅读模式
#1 ERROR(ORCAP-36004): Conflicting values of part name found on different sections of "U3".Conflicting values: S3C2440AL_3_BGA289_S3C2440AL_ & S3C2440AL_2_BGA289_S3C2440AL_ Property values of "Device","PCB FootPrint", "Class" and "Value" should be identical  on all sections of the part.生成网表的时候,这个问题如何解决?我的U3是分成三个部分的(A,B,C),我觉得主要问题估计是在Conflicting values of part name found on different sections of "U3".这一句上,后面几个值我看了应该都是一致的,请哪位好心人帮忙解答一下。。
jjjyufan 发表于 2012-5-2 17:09 | 显示全部楼层
3部分的编号应该是U3A U3B U3C
