本文目的:移植RTOS到MM32F0121系列MCU
首先要准备一个MM32F0121基本模板,可以以GPIO_LED_Toggle为基础。
在LibSamples_MM32F0120_V1.13.4中建立了middlewares\freertos目录,复制一份freeRTOS库文件此目录
将freeRTOS下各路径下7个文件添加到工程中
添加include paths
..\..\..\..\..\middlewares\freertos\source\include
..\..\..\..\..\middlewares\freertos\source\portable\rvds\ARM_CM0
在freeRTOS中找到FreeRTOSConfig.h、portmacro.h,复制到工程根目录下
FreeRTOSConfig.h中修改
- #define configUSE_PREEMPTION 1
- #define configUSE_IDLE_HOOK 0
- #define configUSE_TICK_HOOK 0
- #define configCPU_CLOCK_HZ ( 72000000 )
- #define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
- #define configMAX_PRIORITIES ( 5 )
- #define configMINIMAL_STACK_SIZE ( ( unsigned short ) 128 )
- #define configTOTAL_HEAP_SIZE ( ( size_t ) ( 3*1024 ) )
- #define configMAX_TASK_NAME_LEN ( 5 )
- #define configUSE_TRACE_FACILITY 1
- #define configUSE_16_BIT_TICKS 0
- #define configIDLE_SHOULD_YIELD 1
- #define configUSE_MUTEXES 1
- #define configQUEUE_REGISTRY_SIZE 8
- #define configCHECK_FOR_STACK_OVERFLOW 0
- #define configUSE_RECURSIVE_MUTEXES 1
- #define configUSE_MALLOC_FAILED_HOOK 0
- #define configUSE_APPLICATION_TASK_TAG 0
- #define configUSE_COUNTING_SEMAPHORES 1
- #define configGENERATE_RUN_TIME_STATS 0
- /* Co-routine definitions. */
- #define configUSE_CO_ROUTINES 0
- #define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
- /* Software timer definitions. */
- #define configUSE_TIMERS 0
- #define configTIMER_TASK_PRIORITY ( 2 )
- #define configTIMER_QUEUE_LENGTH 5
- #define configTIMER_TASK_STACK_DEPTH ( 80 )
- /* Set the following definitions to 1 to include the API function, or zero
- to exclude the API function. */
- #define INCLUDE_vTaskPrioritySet 1
- #define INCLUDE_uxTaskPriorityGet 1
- #define INCLUDE_vTaskDelete 1
- #define INCLUDE_vTaskCleanUpResources 1
- #define INCLUDE_vTaskSuspend 1
- #define INCLUDE_vTaskDelayUntil 1
- #define INCLUDE_vTaskDelay 1
- /* Normal assert() semantics without relying on the provision of an assert.h
- header file. */
- #define configASSERT( x ) if( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
- /* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
- standard names - or at least those used in the unmodified vector table. */
- //#define vPortSVCHandler SVC_Handler
- #define xPortPendSVHandler PendSV_Handler
- #define xPortSysTickHandler SysTick_Handler
- #endif /* FREERTOS_CONFIG_H */
注意其中:
#define configCPU_CLOCK_HZ ( 72000000 ) //主频72MHZ
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 128 ) //stack根据情况设置,LED task可以设小点,printf需要设大一点
#define xPortPendSVHandler PendSV_Handler //
#define xPortSysTickHandler SysTick_Handler //这两个中断需要被freeRTOS接管
mm32f0120_it.c中将这两个中断处理函数注释掉,避免编译冲突
- void PendSV_Handler(void)
- void SysTick_Handler(void)
- if (0 != PLATFORM_DelayTick)
- PLATFORM_DelayTick--;
main()修改,执行freeRTOS_Sample()
- int main(void)
- PLATFORM_Init();
- freeRTOS_Sample();
- while (1)
PLATFORM_Init中注释掉PLATFORM_InitDelay()
- void PLATFORM_Init(void)
- // PLATFORM_InitDelay();
- PLATFORM_InitConsole(115200);
- PLATFORM_InitLED();
- PLATFORM_PrintInfo();
新建freeRTOS_demo.c存放以下内容:
freeRTOS_Sample()
建立3个Task
#define PRINT_TASK_STACK_SIZE (256) // 256 words = 1024 bytes
#define LED_TASK_STACK_SIZE (configMINIMAL_STACK_SIZE) // 128 words = 512 bytes
- void freeRTOS_Sample(void)
- printf("【灵动微电子MM32F0121测评】8、移植RTOS到MM32F0121系列MCU\r\n");
- SysTick_Init();
- xTaskCreate( vLED1Task, "LED1", LED_TASK_STACK_SIZE, NULL, tskIDLE_PRIORITY + 6 , NULL );
- xTaskCreate( vLED2Task, "LED2", LED_TASK_STACK_SIZE, NULL, tskIDLE_PRIORITY + 7 , NULL );
- xTaskCreate( printTask, "print", PRINT_TASK_STACK_SIZE, NULL, tskIDLE_PRIORITY + 8 , NULL );
- vTaskStartScheduler();
- while(1); // 正常情况下不会执行到这里
SysTick_Init()
- static void SysTick_Init(void)
- if (SysTick_Config(SystemCoreClock / configTICK_RATE_HZ)) {
- printf("SysTick config failed\r\n");
- while (1); // 初始化失败
三个TASK
- void vLED1Task( void *pvParameters )
- for( ;; )
- PLATFORM_LED_Toggle(LED1);
- //printf("1 Free Heap: %d\n", xPortGetFreeHeapSize());
- vTaskDelay(pdMS_TO_TICKS(100));
- void vLED2Task( void *pvParameters )
- for( ;; )
- PLATFORM_LED_Toggle(LED2);
- //printf("2 Free Heap: %d\n", xPortGetFreeHeapSize());
- vTaskDelay(pdMS_TO_TICKS(500));
- void printTask( void *pvParameters )
- for( ;; )
- printf("Hello 21ic, Hello MM32F0121\r\n");
- vTaskDelay(pdMS_TO_TICKS(2000));
运行情况:
