[APM32F4] 这里哪个是编码器功能
1722|3
Tom952331 发表于 2025-8-22 15:23 | 显示全部楼层 |阅读模式
极海的SDK里有这个一个程序:
代码为:
  1. #include "main.h"
  2. #include "Board.h"
  3. /* Private includes *******************************************************/
  4. /* Private macro **********************************************************/
  5. /* printf function configs to USART2*/
  6. #define DEBUG_USART  USART2
  7. #define DIV 167
  8. /* Private typedef ********************************************************/
  9. /* Private variables ******************************************************/
  10. uint16_t encoderNum = 0;
  11. volatile uint32_t tick = 0;
  12. /* Private function prototypes ********************************************/
  13. /* External variables *****************************************************/
  14. /* External functions *****************************************************/
  15. /*!
  16. * [url=home.php?mod=space&uid=247401]@brief[/url]       Main program
  17. *
  18. * @param       None
  19. *
  20. * @retval      None
  21. */
  22. int main(void)
  23. {
  24.     GPIO_Config_T    gpioConfig;
  25.     USART_Config_T   usartConfig;
  26.     TMR_BaseConfig_T baseConfig;
  27.     TMR_ICConfig_T   ICConfig;
  28.     BOARD_LEDInit(LED2);
  29.     BOARD_LEDOff(LED2);
  30.     /* USART2 Tx PA2 Rx PA3 */
  31.     usartConfig.baudRate = 115200;
  32.     usartConfig.mode     = USART_MODE_TX_RX;
  33.     usartConfig.hardwareFlow = USART_HARDWARE_FLOW_NONE;
  34.     usartConfig.parity   = USART_PARITY_NONE;
  35.     usartConfig.stopBits =  USART_STOP_BIT_1;
  36.     usartConfig.wordLength = USART_WORD_LEN_8B;
  37.     BOARD_COMInit(COM2,&usartConfig);
  38.     /* Enable GPIOA Periph Clock */
  39.     RCM_EnableAHB1PeriphClock(RCM_AHB1_PERIPH_GPIOA);
  40.     /* Config GPIO */
  41.     gpioConfig.pin = GPIO_PIN_8 | GPIO_PIN_9;
  42.     gpioConfig.mode = GPIO_MODE_AF;
  43.     gpioConfig.speed = GPIO_SPEED_100MHz;
  44.     gpioConfig.otype = GPIO_OTYPE_OD;
  45.     gpioConfig.pupd = GPIO_PUPD_UP;
  46.     GPIO_Config(GPIOA,&gpioConfig);
  47.     /* Config GPIOA  Alernate Function for TMR1  */
  48.     GPIO_ConfigPinAF(GPIOA,GPIO_PIN_SOURCE_8,GPIO_AF_TMR1);
  49.     GPIO_ConfigPinAF(GPIOA,GPIO_PIN_SOURCE_9,GPIO_AF_TMR1);
  50.     /* Enable TMR1,TMR2 Periph Clock */
  51.     RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_TMR1);
  52.     RCM_EnableAPB1PeriphClock(RCM_APB1_PERIPH_TMR2);
  53.     /* Config TMR1 */
  54.     baseConfig.clockDivision = TMR_CLOCK_DIV_1;
  55.     baseConfig.countMode = TMR_COUNTER_MODE_UP;
  56.     baseConfig.division = DIV;
  57.     baseConfig.period = 0x0008;
  58.     baseConfig.repetitionCounter = 0;
  59.     TMR_ConfigTimeBase(TMR1, &baseConfig);
  60.     /* Config TMR2 */
  61.     baseConfig.clockDivision = TMR_CLOCK_DIV_1;
  62.     baseConfig.countMode = TMR_COUNTER_MODE_UP;
  63.     baseConfig.division = DIV;
  64.     baseConfig.period = 999;
  65.     baseConfig.repetitionCounter = 0;
  66.     TMR_ConfigTimeBase(TMR2, &baseConfig);
  67.     /* Encoder */
  68.     TMR_ConfigEncodeInterface(TMR1,TMR_ENCODER_MODE_TI1,TMR_IC_POLARITY_RISING,TMR_IC_POLARITY_RISING);
  69.     /* Input Capture */
  70.     ICConfig.channel = TMR_CHANNEL_1;
  71.     ICConfig.polarity = TMR_IC_POLARITY_RISING;
  72.     ICConfig.selection = TMR_IC_SELECTION_DIRECT_TI;
  73.     ICConfig.prescaler = TMR_IC_PSC_1;
  74.     ICConfig.filter = 0;
  75.     TMR_ConfigIC(TMR1,&ICConfig);
  76.     ICConfig.channel = TMR_CHANNEL_2;
  77.     TMR_ConfigIC(TMR1,&ICConfig);
  78.
  79.     /* Counter */
  80.     TMR_ConfigCounter(TMR1,0x0004);
  81.     TMR_ClearStatusFlag(TMR1,TMR_FLAG_UPDATE);
  82.     TMR_ClearStatusFlag(TMR2,TMR_FLAG_UPDATE);
  83.     /* Enable TMR1,TMR2 Interrupt */
  84.     TMR_EnableInterrupt(TMR1, TMR_INT_UPDATE);
  85.     TMR_EnableInterrupt(TMR2, TMR_INT_UPDATE);
  86.     NVIC_EnableIRQRequest(TMR1_UP_TMR10_IRQn, 0, 0);
  87.     NVIC_EnableIRQRequest(TMR2_IRQn, 0, 0);
  88.     /* Enable TMR1,TMR2 */
  89.     TMR_Enable(TMR1);
  90.     TMR_Enable(TMR2);
  91.     while(1)
  92.     {
  93.         BOARD_LEDToggle(LED2);
  94.         Delay();
  95.     }
  96. }
可是查数据手册:
这PA8,PA9哪个是编码器功能?谢谢
fxyc87 发表于 2025-8-22 16:08 | 显示全部楼层
TMR1_CH1,CH2
定时器1输入
 楼主| Tom952331 发表于 2025-8-22 16:10 | 显示全部楼层
幻影书记 发表于 2025-8-22 16:23 | 显示全部楼层
这就是一个输入捕获
