TI LaunchPad开发板问题求教
 楼主| yuzhexian 发表于 2012-7-26 07:26 | 显示全部楼层 |阅读模式
运气不错,拿到了TI LaunchPad开发板,可编程时提示main() at main.c:35 0xC000 和c_int00_noexit() 0xC122  (the entry point was reached)
求好心人指教问题在哪,我用的是ti实用程序,是把开发板插在usb口编程的,板上跳线没有动,都是接上的,编程时不知道要不要改变,程序如下:
//   MSP430G2xx3 Demo - USCI_A0, Ultra-Low Pwr UART 9600 RX/TX, 32kHz ACLK
//   Description: This program demonstrates a full-duplex 9600-baud UART using
//   USCI_A0 and a 32kHz crystal.  The program will wait in LPM3, and receive
//   a string1 into RAM, and echo back the complete string.
//   ACLK = BRCLK = LFXT1 = 32768Hz, MCLK = SMCLK = DCO ~1.2MHz
//   Baud rate divider with 32768Hz XTAL @9600 = 32768Hz/9600 = 3.41
//* An external watch crystal is required on XIN XOUT for ACLK *//
//                MSP430G2xx3
//         /|\|              XIN|-
//          | |                 | 32kHz
//          --|RST          XOUT|-
//            |     P1.2/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P1.1/UCA0RXD|<------------
//   D. Dang
//   Texas Instruments Inc.
//   February 2011
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include  "msp430g2553.h"
char string1[8];
char i;
char j = 0;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR = 0xFF;                             // All P1.x outputs
  P1OUT = 0;                                // All P1.x reset
  P2DIR = 0xFF;                             // All P2.x outputs
  P2OUT = 0;                                // All P2.x reset
  P1SEL = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P1SEL2 = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P3DIR = 0xFF;                             // All P3.x outputs
  P3OUT = 0;                                // All P3.x reset
  UCA0CTL1 |= UCSSEL_1;                     // CLK = ACLK
  UCA0BR0 = 0x03;                           // 32kHz/9600 = 3.41
  UCA0BR1 = 0x00;                           //
  UCA0MCTL = UCBRS1 + UCBRS0;               // Modulation UCBRSx = 3
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM3_bits + GIE);       // Enter LPM3, interrupts enabled
// USCI A0/B0 Transmit ISR
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
  UCA0TXBUF = string1[i++];                 // TX next character
  if (i == sizeof string1)                  // TX over?
    IE2 &= ~UCA0TXIE;                       // Disable USCI_A0 TX interrupt
// USCI A0/B0 Receive ISR
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  string1[j++] = UCA0RXBUF;
  if (j > sizeof string1 - 1)
    i = 0;
    j = 0;
    IE2 |= UCA0TXIE;                        // Enable USCI_A0 TX interrupt
consif 发表于 2012-7-26 09:57 | 显示全部楼层
launchpad 没有P3口的。。。类似还有问题
zhl100 发表于 2012-7-26 15:39 | 显示全部楼层
我写的串口收发都正常的。你这是哪来的程序。。。
TI官网有 msp430g2xx3的c历程  你在看看寄存器   中文手册都出来   不过寄存器的还是英文的
永远的不知 发表于 2012-7-26 17:00 | 显示全部楼层
1# yuzhexian
你指的是编译时出错,还是下载或调试时出错?
