[ZLG-ARM] 向大神请教
 楼主| IC!=ISEE 发表于 2013-10-27 15:08 | 显示全部楼层 |阅读模式
在ADS1.2环境下,下面程序1不会报错,调了一下的程序2相同程序却报错,那是为什么?
我只是调换了中断函数void __irq IRQ__eint0(void)
与函数void interrupt_init(void)
的顺序。
程序1:
#include "config.h"
#define  port 0xff<<18
uint8 tab[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
void output(uint8 data)
{        IO1SET|=port;
        //IO1CLR|=port;
        IO1CLR|=((~data)<<18);
  void delayns(uint32 dly)
        uint32 i;
        for(;dly>0;dly--)
        for(i=0;i<50000;i++);
void io_init(void)
        PINSEL1=(PINSEL1&0xfffffffc)|0x01;
        PINSEL2&=(~0x08);
        IO1DIR|=port;
   uint8 i;
   for(i=0;i<8;i++)
                   output(0x77);
                   delayns(20);
                   output(0xff);
                   delayns(20);
           while((EXTINT&0x01)!=0)
           EXTINT=0x01;
           VICVectAddr=0;
        EXTMODE=EXTMODE&0x0E;
        EXTPOLAR=EXTPOLAR&0x0E;
        IRQEnable();
        VICIntSelect=VICIntSelect&(~(1<<14));
        VICVectCntl0=0x20|14;
        VICVectAddr0= (uint32)IRQ__eint0;
        EXTINT=0x01;
        VICIntEnable=(1<<14);
        int main (void)
{// add user source code
        uint8 i;
        io_init();
        interrupt_init();
        while(1)
        output(tab[i]);
        delayns(20);
        i++;
        if(i==8)
        i=0;
    return 0;
程序2:
#include "config.h"
{        IO1SET|=port;
        //IO1CLR|=port;
        uint32 i;
        for(;dly>0;dly--)
void io_init(void)
        PINSEL2&=(~0x08);
        IO1DIR|=port;
        IRQEnable();
        EXTINT=0x01;
   uint8 i;
   for(i=0;i<8;i++)
                   output(0x77);
                   delayns(20);
                   output(0xff);
                   delayns(20);
           EXTINT=0x01;
           VICVectAddr=0;
报错情况是:Error   : C2456E: undeclared name, inventing 'extern int IRQ__eint0'
main.c line 56
Error   : (Serious) C2933E: type disagreement for 'IRQ__eint0'
main.c line 62
D:\ARM\interrupt\src\main.c: 0 warnings, 1 error, 1 serious error
