[STM32F4] STM32F4时钟设置分析
 楼主| powerful1 发表于 2015-3-22 23:28 | 显示全部楼层 |阅读模式
环境:
主机:WIN7
开发环境:MDK4.72
MCU:STM32F407VGT6
STM32F4启动与STM32F10X不同,时钟已经默认配置好.
1.启动代码:
文件:startup_stm32f4xx.s
[cpp] view plaincopy
  • <span style="font-family:KaiTi_GB2312;font-size:18px;">; Reset handler
  • Reset_Handler    PROC
  •                  EXPORT  Reset_Handler             [WEAK]
  •         IMPORT  SystemInit
  •         IMPORT  __main
  •                  LDR     R0, =SystemInit
  •                  BLX     R0
  •                  LDR     R0, =__main
  •                  BX      R0
  •                  ENDP</span>
可以看出,在进入main函数之前,系统调用了SystemInit函数.
2.SystemInit函数分析
SystemInit函数位于system_stm32f4xx.c文件中.此文件提供几个宏定义可以设置各个时钟:
  • <span style="font-family:KaiTi_GB2312;font-size:18px;">/************************* PLL Parameters *************************************/
  • /* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N */
  • #define PLL_M      25
  • #define PLL_N      336
  • /* SYSCLK = PLL_VCO / PLL_P */
  • #define PLL_P      2
  • /* USB OTG FS, SDIO and RNG Clock =  PLL_VCO / PLLQ */
  • #define PLL_Q      7
  • /******************************************************************************/</span>
 楼主| powerful1 发表于 2015-3-22 23:29 | 显示全部楼层
而晶振频率则是在文件stm32f4xx.h中进行设置:
外部晶振:
  • <span style="font-family:KaiTi_GB2312;font-size:18px;">#if !defined  (HSE_VALUE)
  •   #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
  • #endif /* HSE_VALUE */</span>
内部晶振:
  • <span style="font-family:KaiTi_GB2312;font-size:18px;">#if !defined  (HSI_VALUE)
  •   #define HSI_VALUE    ((uint32_t)16000000) /*!< Value of the Internal oscillator in Hz*/
  • #endif /* HSI_VALUE */ </span>
综上,可以得出默认配置中:
锁相环压腔振荡器时钟PLL_VCO = 25 / 25 * 336 = 336MHz
系统时钟SYSCLK = 336 / 2 = 168MHz
USB,SD卡时钟 = 336 / 7 = 48MHz
时钟图:
 楼主| powerful1 发表于 2015-3-22 23:30 | 显示全部楼层
SystemInit函数代码:
  •   * @brief  Setup the microcontroller system
  •   *         Initialize the Embedded Flash Interface, the PLL and update the
  •   *         SystemFrequency variable.
  •   * @param  None
  •   * @retval None
  • void SystemInit(void)
  •   /* FPU settings ------------------------------------------------------------*/
  •   #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
  •     SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2));  /* set CP10 and CP11 Full Access */
  •   #endif
  •   /* Reset the RCC clock configuration to the default reset state ------------*/
  •   /* Set HSION bit */
  •   RCC->CR |= (uint32_t)0x00000001;
  •   /* Reset CFGR register */
  •   RCC->CFGR = 0x00000000;
  •   /* Reset HSEON, CSSON and PLLON bits */
  •   RCC->CR &= (uint32_t)0xFEF6FFFF;
  •   /* Reset PLLCFGR register */
  •   RCC->PLLCFGR = 0x24003010;
  •   /* Reset HSEBYP bit */
  •   RCC->CR &= (uint32_t)0xFFFBFFFF;
  •   /* Disable all interrupts */
  •   RCC->CIR = 0x00000000;
  • #ifdef DATA_IN_ExtSRAM
  •   SystemInit_ExtMemCtl();
  • #endif /* DATA_IN_ExtSRAM */
  •   /* Configure the System clock source, PLL Multiplier and Divider factors,
  •      AHB/APBx prescalers and Flash settings ----------------------------------*/
  •   SetSysClock();
  •   /* Configure the Vector Table location add offset address ------------------*/
  • #ifdef VECT_TAB_SRAM
  •   SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
  • #else
  •   SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
  • #endif
  • }</span>
3.SetSysClock函数分析
在SetSysClock函数中,配置了系统时钟,PLL倍频以及分频系数:
[cpp] view plaincopy在CODE上查看代码片派生到我的代码片
  * @brief  Configures the System clock source, PLL Multiplier and Divider factors,
  *         AHB/APBx prescalers and Flash settings
  * @NOTE   This function should be called only once the RCC clock configuration
  *         is reset to the default reset state (done in SystemInit() function).
  * @param  None
  * @retval None
static void SetSysClock(void)
/*            PLL (clocked by HSE) used as System clock source                */
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Select regulator voltage output Scale 1 mode, System frequency up to 168 MHz */
    RCC->APB1ENR |= RCC_APB1ENR_PWREN;
    PWR->CR |= PWR_CR_VOS;
    /* HCLK = SYSCLK / 1*/
    RCC->CFGR |= RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK / 2*/
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV2;
    /* PCLK1 = HCLK / 4*/
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV4;
    /* Configure the main PLL */
    RCC->;PLLCFGR = PLL_M | (PLL_N << 6) | (((PLL_P >> 1) -1) << 16) |
                   (RCC_PLLCFGR_PLLSRC_HSE) | (PLL_Q << 24);
    /* Enable the main PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till the main PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Configure Flash prefetch, Instruction cache, Data cache and wait state */
    FLASH->ACR = FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_5WS;
    /* Select the main PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= RCC_CFGR_SW_PLL;
    /* Wait till the main PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL);
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
}</span>
如果外部时钟启动失败,系统会使用内部时钟
默认配置:
HCLK = SYSCLK / 1 = 168MHz
PCLK2 = HCLK / 2 = 84MHz
PCLK1 = HCLK / 4 = 42MHz
