做完了 Blink,再做一个 Fade,就是通常所说的呼吸灯。因为要用到 PWM 输出功能,所以,LED 要从 D8 换到 D9,因为Arduino UNO 具备 PWM 功能的管脚位于:D3,D5,D6,D9,D10,D11。
实验过程是这样:通过一个外接到 A0 脚的电位器调节连接到 D9 脚的 LED 的亮度。
Arduino 代码是这样:
- Fade
- This example shows how to fade an LED on pin 9 using the analogWrite()
- function through a potentiometer connected to A0.
- The analogWrite() function uses PWM, so if you want to change the pin you're
- using, be sure to use another PWM capable pin. On most Arduino, the PWM pins
- are identified with a "~" sign, like ~3, ~5, ~6, ~9, ~10 and ~11.
- const int led = 9; // the PWM pin the LED is attached to
- const int pot = A0; // the ADC0 channel connected to potentiometer
- int brightness = 0; // how bright the LED is
- int fadeAmount = 0; // how many points to fade the LED by potentiometer
- // the setup routine runs once when you press reset:
- void setup() {
- // declare pin 9 to be an output:
- pinMode(led, OUTPUT);
- pinMode(pot, INPUT);
- // for debugging:
- Serial.begin(115200);
- // the loop routine runs over and over again forever:
- void loop() {
- // read the potentiometer from A0:
- fadeAmount = analogRead(pot);
- // map the value from 0-1023 to 0-255:
- brightness = map(fadeAmount, 0, 1023, 0, 255);
- // set the brightness of pin 9:
- analogWrite(led, brightness);
- // show the PWM value on Serial Monitor:
- Serial.print("Current PWM: ");
- Serial.println(brightness);
- // wait for 30 milliseconds to see the dimming effect
- delay(30);
