linux内核进程切换最重要的一个部分就是宏定义switch_to,下面从几个方面来详细讲解一下:<br />(1)内嵌汇编<br />(2)memory 破坏描述符(编译器优化)<br />(3)进程切换的标志是什么?<br />(4)堆栈切换的标志是什么?<br />(5)为什么switch_to 提供了三个参数?<br />(6)汇编参数的传递?<br /><br />带着这几个问题,先来大体浏览一下代码<br /><br />#define switch_to(prev, next, last) <br />do { <br />/* <br /> * Context-switching clobbers(彻底击败) all registers, so we clobber <br /> * them explicitly, via unused output variables. <br /> * (EAX and EBP is not listed because EBP is saved/restored <br /> * explicitly for wchan access and EAX is the return value of <br /> * __switch_to()) <br /> */ <br />unsigned long ebx, ecx, edx, esi, edi; <br /> <br />asm volatile("pushfl
" /* save flags */ <br /> "pushl %%ebp
" /* save EBP */ <br /> "movl %%esp,%[prev_sp]
" /* save ESP */ <br /> "movl %[next_sp],%%esp
" /* restore ESP */ <br /> "movl $1f,%[prev_ip]
" /* save EIP */ <br /> "pushl %[next_ip]
" /* restore EIP */ <br /> "jmp __switch_to
" /* regparm call */ <br /> "1: " <br /> "popl %%ebp
" /* restore EBP */ <br /> "popfl
" /* restore flags */ <br /> <br /> /* output parameters */ <br /> : [prev_sp] "=m" (prev->thread.sp), <br /> /*m表示把变量放入内存,即把[prev_sp]存储的变量放入内存,最后再写入prev->thread.sp*/<br /> [prev_ip] "=m" (prev->thread.ip), <br /> "=a" (last), <br /> /*=表示输出,a表示把变量last放入ax,eax = last*/ <br /> <br /> /* clobbered output registers: */ <br /> "=b" (ebx), "=c" (ecx), "=d" (edx), <br /> /*b 变量放入ebx,c表示放入ecx,d放入edx,S放入si,D放入edi*/<br /> "=S" (esi), "=D" (edi) <br /> <br /> /* input parameters: */ <br /> : [next_sp] "m" (next->thread.sp), <br /> /*next->thread.sp 放入内存中的[next_sp]*/<br /> [next_ip] "m" (next->thread.ip), <br /> <br /> /* regparm parameters for __switch_to(): */ <br /> [prev] "a" (prev), <br /> /*eax = prev edx = next*/<br /> [next] "d" (next) <br /> <br /> : /* reloaded segment registers */ <br /> "memory"); <br />} while (0)<br /><br />以上代码,主要是内嵌汇编,这里先简单介绍一下:<br /> 1 内嵌汇编语法<br />__asm__ __violate__ ("movl %1,%0" : "=r" (result) : "m" (input));<br /><br />__asm__ __violate__("指令模板" : 输出部 : 输入部);<br /><br />“movl %1,%0”是指令模板;“%0”和“%1”代表指令的操作数,称为占位符,内嵌汇<br />编靠它们将C 语言表达式与指令操作数相对应。指令模板后面用小括号括起来的是C语言表<br />达式,本例中只有两个:“result”和“input”,他们按照出现的顺序分别与指令操作数“%0”,<br />“%1”对应;注意对应顺序:第一个C 表达式对应“%0”;第二个表达式对应“%1”,依次类<br />推,操作数至多有10 个,分别用“%0”,“%1”….“%9”表示。在每个操作数前面有一个<br />用引号括起来的字符串,字符串的内容是对该操作数的限制或者说要求。“result”前面的<br />限制字符串是“=r”,其中“=”表示“result”是输出操作数,“r”表示需要将“result”<br />与某个通用寄存器相关联,先将操作数的值读入寄存器,然后在指令中使用相应寄存器,而<br />不是“result”本身,当然指令执行完后需要将寄存器中的值存入变量“result”,从表面<br />上看好像是指令直接对“result”进行操作,实际上GCC做了隐式处理,这样我们可以少写<br />一些指令。“input”前面的“r”表示该表达式需要先放入某个寄存器,然后在指令中使用<br />该寄存器参加运算。<br />(2)memory 破坏描述符(编译器优化)<br />内存访问速度远不及CPU处理速度,为提高机器整体性能,在硬件上引入硬件高速缓存<br />Cache,加速对内存的访问。另外在现代CPU中指令的执行并不一定严格按照顺序执行,没<br />有相关性的指令可以乱序执行,以充分利用CPU的指令流水线,提高执行速度。以上是硬件<br />级别的优化。再看软件一级的优化:一种是在编写代码时由程序员优化,另一种是由编译器<br />进行优化。编译器优化常用的方法有:将内存变量缓存到寄存器;调整指令顺序充分利用<br />CPU指令流水线,常见的是重新排序读写指令。<br />对常规内存进行优化的时候,这些优化是透明的,而且效率很好。由编译器优化或者硬<br />件重新排序引起的问题的解决办法是在从硬件(或者其他处理器)的角度看必须以特定顺序<br />执行的操作之间设置内存屏障(memory barrier),linux 提供了一个宏解决编译器的执行<br />顺序问题。<br />void Barrier(void)<br />这个函数通知编译器插入一个内存屏障,但对硬件无效,编译后的代码会把当前CPU寄存器<br />中的所有修改过的数值存入内存,需要这些数据的时候再重新从内存中读出。<br />Memory描述符告知GCC:<br />l 1)不要将该段内嵌汇编指令与前面的指令重新排序;也就是在执行内嵌汇编代码<br />之前,它前面的指令都执行完毕<br />l 2)不要将变量缓存到寄存器,因为这段代码可能会用到内存变量,而这些内存变<br />量会以不可预知的方式发生改变,因此GCC插入必要的代码先将缓存到寄存器的变<br />量值写回内存,如果后面又访问这些变量,需要重新访问内存。<br />如果汇编指令修改了内存,但是GCC 本身却察觉不到,因为在输出部分没有描述,此时<br />就需要在修改描述部分增加“memory”,告诉GCC 内存已经被修改,GCC 得知这个信息后,<br />就会在这段指令之前,插入必要的指令将前面因为优化Cache 到寄存器中的变量值先写回内<br />存,如果以后又要使用这些变量再重新读取。<br />(3)进程切换的标志-----sp指针的切换<br /> 因为进程切换也就是进程描述符的切换,现在让我们来想一下我们是如何定位某个进程描述符的地址的,看下面的汇编代码:<br /> mov $0xffffe000,%ecx<br /> andl %esp,%ecx<br /> movl %ecx,p<br /><br />执行上面代码后,p中即存储当前运行进程的thread_info结构的地址,但是我们最长用的是进程描述符的地址,因此内核设计了current宏来计算指向进程描述符的指针:<br />mov $0xfffe000,%ecx<br />andl %esp,%ecx<br />movl (%ecx),p<br />因为task字段在thread_info中的偏移量为0,所以执行上述三条指令后,p即是当前运行的进程的描述符指针。<br /> 我们可以看到,只要知道esp,那么,进程就唯一确定了,所以说esp是进程切换的标志<br />(4)堆栈切换的标志 --- ebp (栈低指针)<br /> 毋庸置疑,栈底指针肯定是堆栈切换的标志<br />(5)switch_to 三个参数<br />进程切换一般都涉及三个进程,如进程a切换成进程b,b开始执行,但是当a恢复执行的时候往往是通过一个进程c,而不是进程b。注意switch_to的调用: switch_to(prev,next,prev), 可以看到last就是prev 调用方法如下:进程A->进程B switch_to(A,B,A)主要有三个参数:<br />输入参数两个:prev:切换前的进程,next:切换后的进程,输出参数一个:last:切换前进程。 <br />注意这三个变量都是局部变量,在系统栈中,所以切换到另一进程后变量的值不会改变。<br />进程a切换b之前,eax的值为prev,也就是A;edx的值为next,也就是B,eax的值为last,也就是A<br />当不考虑第三个参数时,从C切换成A,内核栈切换成A的栈,这时A中的prev和nexxt分别指向A和B,进程C的引用丢失了。这时第三个参数就派上用场了。C切换进程A后,将C存入eax中,切换到A后,由于输出部"=a" (last)会将eax的值写入last中,也就是prev中,所以此时prev和next的值就是C和B了。<br />(6)汇编参数的传递?<br />汇编是通过寄存器传递参数的,这里用了eax和edx,这样jmp就和call差不多了,但是jmp和call的区别是,call会有硬件自动压栈一些寄存器的,比如cs:ip ,这里是通过手工压栈ip,模拟了call,在__switch_to中,用return 返回。我们又会想到为什么不用call呢?原因是进入__switch_to后,我们是为运行别的进程做准备,也就是说当返回的时候应该是运行next进程而不是当前进程。如果用call的话,压栈的是当前进程的ip,那么__switch_to返回后就运行当前进程了,这与我们想运行next的进程的想法是不一致的,因此,我们手工压栈的是next进程的ip,那么,当__switch_to返回后自然出栈的就是next的ip,也就是运行next进程了。 |
