单片机:STM8S105K4T6
编程环境:STVD+COSMIC
使用引脚:PB0
实际现象:外接0v,转换结果0x0000 (好像小于1.6v都是0);外接1.6V,转换结果0x03ff ;外接3.3v,转换结果0x037f (好像大于2v都是0x037f) ;
问题代码如下:
main.c文件
- /* name : main.c */
- /* berif : */
- /* Include: stm8s105k.h */
- /* stm8s105k_led.h */
- /* include-------------------------------------------------------------------*/
- #include "stm8s105k.h"
- #include "stm8s105k_led.h"
- /* define--------------------------------------------------------------------*/
- /* extern--------------------------------------------------------------------*/
- extern uint8_t ADC1_CONVER_FLAG;
- /* main()--------------------------------------------------------------------*/
- void main()
- /* 局部变量定义------------------------------------------------------------*/
- uint8_t i;
- //open global interrupt
- enableInterrupts();
- //direction runing is ok
- LED_Init;LED_ON;
- CLK_CKDIVR = (CLK_CKDIVR_HSIDIV_2 | CLK_CKDIVR_CPUDIV_1);
- /* ADC1初始化部分----------------------------------------------------------*/
- //1.引脚模式:浮空输入
- PB_DDR &= (uint8_t)~(1<<0);
- PB_CR1 &= (uint8_t)~(1<<0);
- PB_CR2 &= (uint8_t)~(1<<0);
- //2.打开ADC时钟
- CLK_PCKENR2 |= (uint8_t)(1<<3);
- //3.选择ADC转换通道
- ADC_CSR &= 0xF0;//通道0
- ADC_CSR |= 0x00;
- //4.关闭使用通道的斯密特触发器
- ADC_TDRL |= (uint8_t)(1<<0);
- //5.设置转换模式:带缓存的连续模式
- ADC_CR1 |= (uint8_t)(1<<1);//使能连续转换
- //(缓存满时,置位EOC,然后自动开始下一轮转换,所以进中断的第一件事是清CONT)
- ADC_CR3 |= (uint8_t)(1<<7);//使用缓存
- //6.关闭使用通道的模拟看门狗功能
- ADC_AWCRL &= (uint8_t)~(1<<0);
- //7.禁止模拟看门狗中断
- ADC_CSR &= (uint8_t)~(1<<4);//写“0”禁止
- //8.清除模拟看门狗中断标志
- ADC_CSR &= (uint8_t)~(1<<6);
- //9.禁止外部信号触发转换
- ADC_CR2 &= (uint8_t)~(1<<6);
- //10.设置F_ADC频率:F_master/8
- ADC_CR1 &= 0x8F;
- ADC_CR1 |= (uint8_t)0x40;
- //11.使能转换结束中断
- ADC_CSR |= (uint8_t)(1<<5);
- //12.清除转换结束标志
- ADC_CSR &= (uint8_t)~(1<<7);
- //13.设置转换结果数据对齐方式:右对齐
- ADC_CR2 |= (1<<3);//先读低,再读高
- //14.将ADC从低功耗模式中唤醒
- ADC_CR1 |= (uint8_t)(1<<0);
- //15.等待ADC供电稳定(最小7us)
- for(i=0;i<10;i++);//大概20us
- //16.开始转换
- LED_OFF;
- while(1)
- if(ADC1_CONVER_FLAG==1)
- LED_ON;
复制代码
stm8_interrupt_vector.c文件
- /* [url=home.php?mod=space&uid=139335]@name[/url] : stm8_interrupt_vector.c */
- /* [url=home.php?mod=space&uid=247401]@brief[/url] : */
- /* @Include: stm8s105k.h */
- /* $ 别名定义----------------------------------------------------------------*/
- typedef void [url=home.php?mod=space&uid=1095855]@far[/url] (*interrupt_handler_t)(void);
- /* $ 结构体定义--------------------------------------------------------------*/
- struct interrupt_vector {
- unsigned char interrupt_instruction;
- interrupt_handler_t interrupt_handler;
- /* $ 全局变量----------------------------------------------------------------*/
- uint16_t adc1_valtage[10]={'\0'};
- /* $ 运行标志----------------------------------------------------------------*/
- uint8_t ADC1_CONVER_FLAG = 0;
- /* $ 中断函数----------------------------------------------------------------*/
- [url=home.php?mod=space&uid=1095855]@far[/url] [url=home.php?mod=space&uid=422518]@interrupt[/url] void NonHandledInterrupt (void)
- /* in order to detect unexpected events during development,
- it is recommended to set a breakpoint on the following instruction
- return;
- [url=home.php?mod=space&uid=1095855]@far[/url] [url=home.php?mod=space&uid=422518]@interrupt[/url] void ISP_ADC1 (void)
- uint8_t i;
- uint8_t *pDBx = &ADC_DB0RH;
- uint8_t temp_low,temp_high;
- uint16_t temp;
- ADC_CR1 &= (uint8_t)~(1<<1);//关闭连续转换
- if(!(ADC_CR3 & (uint8_t)(1<<6)))//数据没有溢出,则将结果读出
- {//数据右对齐,先读低,后读高
- for(i=0;i<10;i++)
- temp_low = *(pDBx + 1) ;
- temp_high = *pDBx ;
- temp = ((uint16_t)temp_high<<8)+(uint16_t)temp_low;
- adc1_valtage = temp;
- pDBx += 2;
- adc1_valtage[10] = '\0';
- ADC1_CONVER_FLAG = 1;
- else //数据溢出,则从新转换一次
- ADC_CR3 &= (uint8_t)~(1<<6);//清溢出标志
- ADC_CR1 |= (uint8_t) (1<<1);//使能连续转换
- ADC_CR1 |= (uint8_t) (1<<0);//开始转换
- LED_OFF;
- ADC_CSR &= (uint8_t)~(1<<7);//清转换结束标志
- return;
- extern void _stext(); /* startup routine */
- struct interrupt_vector const _vectab[] = {
- {0x82, (interrupt_handler_t)_stext}, /* reset */
- {0x82, NonHandledInterrupt}, /* trap */
- {0x82, NonHandledInterrupt}, /* irq0 */
- {0x82, NonHandledInterrupt}, /* irq1 */
- {0x82, NonHandledInterrupt}, /* irq2 */
- {0x82, NonHandledInterrupt}, /* irq3 */
- {0x82, NonHandledInterrupt}, /* irq4 */
- {0x82, NonHandledInterrupt}, /* irq5 */
- {0x82, NonHandledInterrupt}, /* irq6 */
- {0x82, NonHandledInterrupt}, /* irq7 */
- {0x82, NonHandledInterrupt}, /* irq8 */
- {0x82, NonHandledInterrupt}, /* irq9 */
- {0x82, NonHandledInterrupt}, /* irq10 */
- {0x82, NonHandledInterrupt}, /* irq11 */
- {0x82, NonHandledInterrupt}, /* irq12 */
- {0x82, NonHandledInterrupt}, /* irq13 */
- {0x82, NonHandledInterrupt}, /* irq14 */
- {0x82, NonHandledInterrupt}, /* irq15 */
- {0x82, NonHandledInterrupt}, /* irq16 */
- {0x82, NonHandledInterrupt}, /* irq17 */
- {0x82, NonHandledInterrupt}, /* irq18 */
- {0x82, NonHandledInterrupt}, /* irq19 */
- {0x82, NonHandledInterrupt}, /* irq20 */
- {0x82, NonHandledInterrupt}, /* irq21 */
- {0x82, ISP_ADC1}, /* irq22 */
- {0x82, NonHandledInterrupt}, /* irq23 */
- {0x82, NonHandledInterrupt}, /* irq24 */
- {0x82, NonHandledInterrupt}, /* irq25 */
- {0x82, NonHandledInterrupt}, /* irq26 */
- {0x82, NonHandledInterrupt}, /* irq27 */
- {0x82, NonHandledInterrupt}, /* irq28 */
- {0x82, NonHandledInterrupt}, /* irq29 */
复制代码
stm8s105k_led.h文件
- /* [url=home.php?mod=space&uid=139335]@name[/url] : stm8s105k_led.h */
- #ifndef __STM8S105K_LED_H
- #define __STM8S105K_LED_H
- #define LED_Init PE_DDR |= (uint8_t) (1<<GPIO_PIN_5);\
- PE_CR1 &= (uint8_t)~(1<<GPIO_PIN_5);\
- PE_CR2 &= (uint8_t)~(1<<GPIO_PIN_5);\
- PE_ODR |= (uint8_t) (1<<GPIO_PIN_5)
- #define LED_ON PE_ODR &= (uint8_t)~(1<<GPIO_PIN_5)
- #define LED_OFF PE_ODR |= (uint8_t) (1<<GPIO_PIN_5)
- #define LED_Filp PE_ODR ^= (uint8_t) (1<<GPIO_PIN_5)
- #endif
复制代码
实际运行结果
