还有下面这句话里面的“no preset”怎么理解?<br /><br />When using the MAX1771 in non-bootstrapped<br />mode, there is no preset output operation<br />because V+ is also the output voltage sense point<br />for fixed-output operation. External resistors must<br />be used to set the output voltage. |
