在str71x的hdlc的测试程序中,用timer2为hdlc配置时钟,其中有几处不清楚。请教了。程序如下void clks_init(void) { RCCU_Div2Config (ENABLE); //OSC input is divide by 2 RCCU_PLL1Config(RCCU_PLL1_Mul_12, RCCU_Div_2); //RCLK = 48MHz RCCU_RCLKSourceConfig (RCCU_PLL1_Output); RCCU_MCLKConfig(RCCU_DEFAULT); //MCLK=48MHz RCCU_PCLKConfig(RCCU_Div_2); //PCLK2=24MHz APB2 periph RCCU_FCLKConfig(RCCU_Div_2); //PCLK1=24MHz APB1 periph (fast) RCCU_PLL2Config(RCCU_PLL2_Mul_12, RCCU_Div_2); //configure PLL2 for HDLC clock
//setup timer2 (P0.13) for external HDLC clock connected to HCLK TIM_ClockSourceConfig (TIM2, TIM_INTERNAL ); TIM_PrescalerConfig (TIM2,10 ); //24Mhz/77 = 312KHz TIM_PWMOModeConfig (TIM2,0x7,TIM_LOW,0x7,TIM_HIGH); //square wave output TIM_CounterConfig(TIM2, TIM_START); } 我的问题是为什么倒数第三句TIM_PrescalerConfig (TIM2,10 ); //24Mhz/77 = 312KHz 的注释中是对24m分频,应该是48m对么? 在主函数中://***************** Test 2 External clocking, print receive buffer********************* //External clock (155.8kHz) on PLL2 input HCLK HDLC_XmitClockSourceConfig(HDLC_HTXCKSource);//写波特率的RCKS HDLC_XmitBaudrateConfig(0); HDLC_RecvClockSourceConfig(HDLC_HRXCK);//写预频分因子rcks HDLC_RecvClockPrescalerConfig(0);//写预分频因子prs 问题是://External clock (155.8kHz) on PLL2 input HCLK这句注释看不懂 还有:RCCU_Div2Config (ENABLE); //OSC input is divide by 2这句能理解,但是注释里面用osc?对么?osc不是32k?
