STM32学习初篇
 楼主| brotherwen 发表于 2007-10-24 16:55 | 显示全部楼层 |阅读模式
STM32, rc, tc, se, IO
#include <stm32f10x_map.h>
#include "main.h"
由于学习初没有找到中文资料,翻译了点,不管好坏,贴上来和大家分享吧!!!
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : RCC_DeInit
* Description    : Deinitializes the RCC peripheral registers to their default
*                  reset values.
*                   - The HSITRIM[4:0] bits in RCC_CR register are not modified
*                     by this function.
*                   - The RCC_BDCR and RCC_CSR registers are not reset by this
*                     function.
* Input          : None
* Output         : None
* Return         : None
void RCC_DeInit(void)
  // Disable APB2 Peripheral Reset
  RCC->APB2RSTR = 0x00000000;
  // Disable APB1 Peripheral Reset
  RCC->APB1RSTR = 0x00000000;
  // FLITF and SRAM Clock ON
  RCC->AHBENR = 0x00000014;
  //Disable APB2 Peripheral Clock
  RCC->APB2ENR = 0x00000000;
  // Disable APB1 Peripheral Clock
  RCC->APB1ENR = 0x00000000;
  // Set HSION bit
  RCC->CR |= (u32)0x00000001;
  // Reset SW[1:0], HPRE[3:0], PPRE1[2:0], PPRE2[2:0], ADCPRE[1:0] and MCO[2:0] bits
  RCC->CFGR &= 0xF8FF0000;
  // Reset HSEON, CSSON and PLLON bits
  RCC->CR &= 0xFEF6FFFF;
  // Reset HSEBYP bit
  RCC->CR &= 0xFFFBFFFF;
  // Reset PLLSRC, PLLXTPRE, PLLMUL[3:0] and USBPRE bits
  RCC->CFGR &= 0xFF80FFFF;
  //Disable all interrupts
  RCC->CIR = 0x00000000;
void SetupClock(void)
  /* Reset HSEON and HSEBYP bits before configuring the HSE ------------------*/
  /* Reset HSEON bit */
  RCC->CR &= 0xfffeffff;  //HSEON清零
    /* Reset HSEBYP bit */
  RCC->CR &= 0xfffbffff;  //清除HSEBYP
   /* Set HSEON bit */
  RCC->CR |= 0x00010000; //置位HSEON
    /* Wait till HSE is ready                                                   */
  while ((RCC->CR&0x00020000)== 0);
  //清除HPRE AHB precxaler
  RCC->CFGR&=0xffffff0f;
  //SYSCLK not divided HCLK   = SYSCLK
  RCC->CFGR|=0;
   //清除PPRE2 APB  high speed precxaler
  RCC->CFGR&=0xffffc7ff;
  //HCLK not divided PCLK2=HCLK
  RCC->CFGR|=0;
  //清除PPRE1 APB  low speed precxaler
  RCC->CFGR&=0xfffff8ff;
   //HCLK  divided by 2 PCLK1=HCLK/2
  RCC->CFGR|=0x00000400;
 *(vu32 *)0x40022000 = 0x01;           /* Flash 2 wait state                 */
   /* PLLCLK = 8MHz * 9 = 72 MHz                                              */
  /* Clear PLLSRC, PLLXTPRE and PLLMUL[21:18] bits */
  RCC->CFGR&= 0xffc0ffff;
  //选择HSE作为PLL时钟输入 PLLMUL选择9倍频
  RCC->CFGR|=0x00010000|0x001c0000;
  RCC->CR|=0X01000000; //置位PLLON位
  while((RCC->CR&0x02000000)== 0); //wait till PLL is ready
  //清除 SW System clock Switch
  RCC->CFGR&=0xfffffffc;
  //选择 PLL作为系统时钟
  RCC->CFGR|=0x00000002;
  //等待 PLL作为系统时钟标志置位
  while((RCC->CFGR&0x0000000c)!=0x08);
  // SysTick event each 10 ms with input clock equal to 9MHz (HCLK/8)
  //SysTick->LOAD=90000;
  //SysTick->CTRL |= 0x00000002;
void delay(void)
 uint i,j;
 for(i=0;i<10;i++)
 for(j=0;j<30000;j++);
int main(void)
    RCC_DeInit();
    SetupClock();
    RCC->APB2ENR|=0X08;
    GPIOB->CRH=0X33333333;
    GPIOB->BRR|=0XFFFF;
/**********MCO******************/
    RCC->APB2ENR|=0X04;
    GPIOA->CRH&=0xf0;
    GPIOA->CRH|=0x0b;
    RCC->CFGR|=0X07000000;
   //RCC->APB2ENR|=0x01;
   while(1)
      //GPIOB->BSRR=0X80000000;
      //GPIOB->BSRR=0X00008000;
     GPIOB->ODR|=0X8000;
     //delay();
     GPIOB->ODR&=0X7FFF;
    // delay();
   //while(1);
#ifndef MAIN_H
#define MAIN_H
//#define _RCC
/*#include <stm32f10x_lib.h>     */
#define uchar unsigned char
#define uint  unsigned int
void RCC_DeInit(void);
void SetupClock(void);
#endif
相关链接:http://bbs.21ic.com/upfiles/img/200710/20071024165215319.pdf
 楼主| brotherwen 发表于 2007-10-24 17:08 | 显示全部楼层
补充
以上程序测试  HSE时钟为8M,PLL后,SYSCLK为72M
循环里不回delay();时:
能过BSRR方式, PB15为 3M方波
   ODR方式.PB15 2.18M
RCC部分翻译:
相关链接:http://bbs.21ic.com/upfiles/img/200710/2007102417656930.pdf
香水城 发表于 2007-10-24 18:41 | 显示全部楼层
谢谢分享!如能谈谈体会就更好了。
加油!
 楼主| brotherwen 发表于 2007-10-25 14:47 | 显示全部楼层
体会??
觉得他还行,在摸索中,中断方面好像单片机.
目前的经验是:在配置IO,或哪个功能前,一定把他的时钟使能先
ijk 发表于 2007-10-25 17:57 | 显示全部楼层
外设和它的时钟
“在配置IO,或哪个功能前,一定把他的时钟使能先”
对了,这就是所谓时钟门控的体现,为了实现低功耗,现在的单片机通常都是这样实现的。
张进128 发表于 2007-10-30 08:42 | 显示全部楼层
顶一个
顶一个顶一个顶一个顶一个顶一个
 楼主| brotherwen 发表于 2007-10-31 14:20 | 显示全部楼层
补充 USART部分
该篇没有翻译完,但足以做USART实验
传了几次,好像这篇有点大
传不上来了,算了!
 楼主| brotherwen 发表于 2007-11-2 16:59 | 显示全部楼层
USART1小实验
void delay(void)
 uint i,j;
 for(i=0;i<10;i++)
int main(void)
      uchar dat=0;
    RCC_DeInit();
    SetupClock();
    RCC->APB2ENR|=1<<APB2_IOPBEN;
    GPIOB->BRR|=0XFFFF;
    usart_init();
    sendchar(0x55);
   while(1)
     GPIOB->ODR|=0X8000;
     delay();
     GPIOB->ODR&=0X7FFF;
     delay();
     sendchar(dat);
     dat=recchar();
   //while(1);
#include "main.h"
#define uart1_baud  115200
void usart_init(void)
    unsigned  long  mantissa,fraction,tmp;
    //使能GPIOA  clock
    RCC->APB2ENR|=1<<APB2_IOPAEN;
    //配置 PA9上拉输出,PA10 悬浮输入
    GPIOA->CRH&=~((0X0F<<8)|(0X0F<<4));  //清除相应配置位的内容
    GPIOA->CRH|=(0X0b<<4)|(0X04<<8);    //配置输出输入
    RCC->APB2ENR|=1<<USART1EN;
    //配置波特率   115200        USART1的外设时钟是    APB2        且等于72M
    tmp=25*72000000/(4*uart1_baud);  //100*72000000/(16*uart1_baud);   为//为了取小数位,放大了一百倍
    mantissa=(tmp/100)&0x0fff;
    fraction=((tmp-mantissa*100)*16+50)/100;
    USART1->BRR=(mantissa<<4)|(fraction&0x0f);
    //数据长度         8位
    USART1->CR1&=~(1<<12);
    //停止位   1位
    USART1->CR2&=~(0x03<<12);
    //奇偶校验    无
    USART1->CR1&=~(1<<10);
    //hardware flow control disable
    USART1->CR3&=~(0X03<<8);
    //使能RX和TX
    USART1->CR1|=(1<<3)|(1<<2);
    //禁止SCK  Clock
    USART1->CR2&=~(1<<11);
    //USART CPOL LOW
    USART1->CR2&=~(1<<10);
    //USART CPHA  2Edge
    USART1->CR2|=1<<9;
    //Last Bit Clock pluse  disable
    USART1->CR2&=~(1<<8);
    //Enable USART1
    USART1->CR1|=1<<13;
void sendchar(uchar dat)
   USART1->DR=dat;
   while(!(USART1->SR&(1<<7)));     //TXE Bit
unsigned  char recchar(void)
{ while(!(USART1->SR&(1<<5)));    //RXNE Bit
  return( uchar)(USART1->DR&0X1FF);
#ifndef MAIN_H
#define MAIN_H
//   外设时钟相应位
#define APB2_IOPBEN    3
#define APB2_IOPAEN    2
#define APB2_AFIOEN    0
#define USART1EN       14
void usart_init(void);
void  sendchar(uchar dat);
unsigned  char recchar(void);
#endif
 楼主| brotherwen 发表于 2007-11-6 15:41 | 显示全部楼层
时钟管脚问题
HSE 管脚PD0 PD1说明好像和数据手册里92页AFIO_MAPR位15 说明不符
HSI 管脚PC14 PC15 到底复位初是什么状态,是接晶振状态? 通用管脚状态??
望大侠们教导下
coyote800 发表于 2011-5-30 21:16 | 显示全部楼层
目前看不懂
xgdxff 发表于 2012-3-21 23:44 | 显示全部楼层
正在学习中 、
yanhaiyuyuyu 发表于 2012-4-24 22:33 | 显示全部楼层
学习中……
gxgclg 发表于 2012-4-24 22:46 | 显示全部楼层
既然是学习笔记,应该多一些文字之类的
