各位好,
想请教一下,keil中device里没有STM32F411RE这颗芯片,我按照下面的方法添加了进去:
Developers can customize or add devices to the Device Database at any time. Though µVision contains many pre-configured standard products, adaptations are needed if the device is not listed.
Open the dialog with the menu File - Device Database.
Double-click a microcontroller similar to the device needed in the application.
Adapt the name of the chip vendor.
Select the appropriate microcontroller family.
Enter the part number for the device.
Modify the description to match the device characteristics.
Add or modify the toolchain configuration parameters in the field Options. Refer to C. Device Database Parameters for more information.
Single-click into the field Data base. This enables the button Add.
Click Add to create a new entry in the Device Database.
但是编译的时候还是很多地方报错,其实就是一些寄存器之类的找不到,也就是说添加芯片资料有问题,所以请教下各位有没有相似添加过device的经验分享一下,谢谢! |
