打着雨伞请教(之3),关于GPIO口的设置问题
 楼主| 程序匠人 发表于 2009-1-23 16:15 | 显示全部楼层 |阅读模式
打着雨伞请教(之3),关于GPIO口在设置为输入状态下是否需要设置速度的问题
以下代码是从万历板载DEMO例程中挖出来的(请注意红色部分):
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
void GPIO_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  /* Configure PC.00 (ADC Channel10) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  // for LCD display -- segment
  /* Configure PE.00 -- PE.15 as Output push-pull : SEG0~15 */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  // for LCD display -- com
  /* Configure PC.08 -- PC.11 as Output push-pull  : COM1~4 */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
  // for 4 LEDs
  /* Configure PC.04 -- PC.07 as Output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  // for KEY2 & KEY3 (PD.3/4) and JoyStick(PD.11~15)
   /* Configure PD.03, PD.04, PD.11 -- PD.15 as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_11 | GPIO_Pin_12 |
      GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  // for usb.cs
    /* PD.08 used as USB pull-up --> EK-STM32F */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  // for JoyStick
  /* Configure the JoyStick IOs */
  /* Key (up + down + left + right */
  GPIO_InitStructure.GPIO_Pin = JOY_UP | JOY_DOWN |JOY_LEFT | JOY_RIGHT;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
从《STM32系列 RAM Cortex-M3微控制器 原理与实践》一书上(第110,表3.11、表3.12)得知,速率仅仅是针对输出模式而言的,而对于输入模式来说,没速率设置一说。
匠人的问题:为什么例程中在把“JOY_UP | JOY_DOWN |JOY_LEFT | JOY_RIGHT”这四个IO口设置为输入上拉模式时,还要设置速率?到底是例程错了,还是书错了,还是匠人错了?
computer00 发表于 2009-1-23 16:28 | 显示全部楼层
多一个操作没影响吧...
 楼主| 程序匠人 发表于 2009-1-23 16:33 | 显示全部楼层
应该没有影响,否则就不会当作demo发布出来了。
匠人关心的不是 是否多一个无效的操作,而是,该操作是否是必须的?
圈圈不回家吗?
computer00 发表于 2009-1-23 16:38 | 显示全部楼层
明天就回,哈哈~~~
ijk 发表于 2009-1-23 16:49 | 显示全部楼层
应该是多此一举
  就公开的资料来看(未公开的资料没看过),这(输入模式下设置速率)应该是多此一举。
