下面是那个例子自带的说明有关使用IAR的部分,请指出你做到那一步:
How to use it ============= In order to load the SysTick example with the IAP, you must do the following: + EWARM: - Open the SysTick.eww workspace - Rebuild all files: Project->Rebuild all - A binary file "SysTick.bin" will be generated under "BOOT_FLASHExe" folder - Finaly load this image with IAP application
