[开发工具] stm32F10XX8/B Rev B不能用IAR v5.2开发?
 楼主| MCUJunior 发表于 2009-2-18 11:35 | 显示全部楼层 |阅读模式
Compilers with improved optimizations for the STM32F10xxx have been recently released on the market. Revisions Z and B of the medium-density STM32F10xxx devices (STM32F10xx8/B) do not support some of the sequences associated with the high-level optimizations done in these compilers. Revision Y is not affected by this limitation.
这是勘误手册上的原话,是指IAR 5.2在高度优化代码时的时序在STM32 10XX8/B Rev B或者Rev X运行不正确?如果选择medium优化或者不优化就可以?
是这个意思吗?
请香版指明。
香水城 发表于 2009-2-18 12:11 | 显示全部楼层
你的理解是对的
不用过于担心,如果有不兼容的情况时,编译器会发出警告信息。
