- * @fn MAC_SrcMatchEnable
- * [url=home.php?mod=space&uid=247401]@brief[/url] Enabled AUTOPEND and source address matching.
- * This function shall be not be called from
- * ISR. It is not thread safe.
- * @param none
- * [url=home.php?mod=space&uid=266161]@return[/url] none
- void MAC_SrcMatchEnable (void)
- /* Turn on Frame Filter (TIMAC enables frame filter by default), TBD */
- MAC_RADIO_TURN_ON_RX_FRAME_FILTERING();
- /* Turn on Auto ACK (TIMAC turn on Auto ACK by default), TBD */
- MAC_RADIO_TURN_ON_AUTO_ACK();
- /* Turn on Autopend: set SRCMATCH.AUTOPEND and SRCMATCH.SRC_MATCH_EN */
- MAC_RADIO_TURN_ON_SRC_MATCH();
- /* Set SRCMATCH.AUTOPEND */
- MAC_RADIO_TURN_ON_AUTOPEND();
- /* AUTOPEND function requires that the received
- * frame is a DATA REQUEST MAC command frame
- MAC_RADIO_TURN_ON_AUTOPEND_DATAREQ_ONLY();
- /* Configure all the globals */
- macSrcMatchIsEnabled = TRUE;
- * @fn MAC_SrcMatchAddEntry
- * @brief Add a short or extended address to source address table. This
- * function shall be not be called from ISR. It is not thread safe.
- * @param addr - a pointer to sAddr_t which contains addrMode
- * and a union of a short 16-bit MAC address or an extended
- * 64-bit MAC address to be added to the source address
- * table.
- * @param panID - the device PAN ID. It is only used when the addr is
- * using short address
- * @return MAC_SUCCESS or MAC_NO_RESOURCES (source address table full)
- * or MAC_DUPLICATED_ENTRY (the entry added is duplicated),
- * or MAC_INVALID_PARAMETER if the input parameters are invalid.
- uint8 MAC_SrcMatchAddEntry ( sAddr_t *addr, uint16 panID )
- uint8 index;
- uint8 entry[MAC_SRCMATCH_SHORT_ENTRY_SIZE];
- /* Check if the input parameters are valid */
- if ( addr == NULL || (addr->addrMode != SADDR_MODE_SHORT && addr->addrMode != SADDR_MODE_EXT))
- return MAC_INVALID_PARAMETER;
- /* Check if the entry already exists. Do not add duplicated entry */
- if ( macSrcMatchCheckSrcAddr( addr, panID ) != MAC_SRCMATCH_INVALID_INDEX )
- return MAC_DUPLICATED_ENTRY;
- /* If not duplicated, write to the radio RAM and enable the control bit */
- /* Find the first empty entry */
- index = macSrcMatchFindEmptyEntry(addr->addrMode);
- if ( (index == MAC_SRCMATCH_SHORT_MAX_NUM_ENTRIES && addr->addrMode == SADDR_MODE_SHORT) ||
- (index == MAC_SRCMATCH_EXT_MAX_NUM_ENTRIES && addr->addrMode == SADDR_MODE_EXT) )
- return MAC_NO_RESOURCES; /* Table is full */
- if ( addr->addrMode == SADDR_MODE_SHORT )
- /* Write the PanID and short address */
- entry[0] = LO_UINT16( panID ); /* Little Endian for the radio RAM */
- entry[1] = HI_UINT16( panID );
- entry[2] = LO_UINT16( addr->addr.shortAddr );
- entry[3] = HI_UINT16( addr->addr.shortAddr );
- MAC_RADIO_SRC_MATCH_TABLE_WRITE( ( index * MAC_SRCMATCH_SHORT_ENTRY_SIZE ),
- entry, MAC_SRCMATCH_SHORT_ENTRY_SIZE );
- else
- /* Write the extended address */
- MAC_RADIO_SRC_MATCH_TABLE_WRITE( ( index * MAC_SRCMATCH_EXT_ENTRY_SIZE ),
- addr->addr.extAddr, MAC_SRCMATCH_EXT_ENTRY_SIZE );
- /* Set the Autopend enable bits */
- macSrcMatchSetPendEnBit( index, addr->addrMode );
- /* Set the Src Match enable bits */
- macSrcMatchSetEnableBit( index, TRUE, addr->addrMode);
- return MAC_SUCCESS;
- * @fn MAC_SrcMatchDeleteEntry
- * @brief Delete a short or extended address from source address table.
- * This function shall be not be called from ISR. It is not thread
- * safe.
- * 64-bit MAC address to be deleted from the source address
- * table.
- * @return MAC_SUCCESS or MAC_INVALID_PARAMETER (address to be deleted
- * cannot be found in the source address table).
- uint8 MAC_SrcMatchDeleteEntry ( sAddr_t *addr, uint16 panID )
- uint8 index;
- /* Look up the source address table and find the entry. */
- index = macSrcMatchCheckSrcAddr( addr, panID );
- if( index == MAC_SRCMATCH_INVALID_INDEX )
- /* Clear Src Match enable bits */
- macSrcMatchSetEnableBit( index, FALSE, addr->addrMode);
- * @fn MAC_SrcMatchAckAllPending
- * @brief Enabled/disable acknowledging all packets with pending bit set
- * The application normally enables it when adding new entries to
- * the source address table fails due to the table is full, or
- * disables it when more entries are deleted and the table has
- * empty slots.
- * @param option - TRUE (acknowledging all packets with pending field set)
- * FALSE (address filtering and FSM control sets the
- * pending field)
- * @return none
- void MAC_SrcMatchAckAllPending ( uint8 option )
- if( option == TRUE )
- macSrcMatchIsAckAllPending = TRUE;
- /* Set the PENDING_OR register */
- MAC_RADIO_TURN_ON_PENDING_OR();
- else
- macSrcMatchIsAckAllPending = FALSE;
- /* Clear the PENDING_OR register */
- MAC_RADIO_TURN_OFF_PENDING_OR();
- * @fn MAC_SrcMatchCheckAllPending
- * @brief Check if acknowledging all packets with pending bit set
- * is enabled.
- * @param none
- * @return MAC_AUTOACK_PENDING_ALL_ON or MAC_AUTOACK_PENDING_ALL_OFF
- uint8 MAC_SrcMatchCheckAllPending ( void )
- if( macSrcMatchIsAckAllPending == TRUE )
- return MAC_AUTOACK_PENDING_ALL_ON;
- return MAC_AUTOACK_PENDING_ALL_OFF;
- * @fn MAC_SrcMatchCheckResult
- * @brief Check the result of source matching
- * @param index - index of the entry in the source address table
- * @return TRUE or FALSE
- MAC_INTERNAL_API bool MAC_SrcMatchCheckResult( void )
- uint8 resIndex;
- if ( macSrcMatchIsAckAllPending )
- return (TRUE);
- MAC_RADIO_SRC_MATCH_RESINDEX( resIndex );
- return ( resIndex & AUTOPEND_RES );
- * @fn macSrcMatchFindEmptyEntry
- * @brief return index of the first empty entry found
- * @param macSrcMatchAddrMode - Address Mode for the entry. Valid values
- * are SADDR_MODE_SHORT or SADDR_MODE_EXT
- * @return uint8 - return index of the first empty entry found
- static uint8 macSrcMatchFindEmptyEntry( uint8 macSrcMatchAddrMode )
- uint8 index;
- uint24 shortAddrEnable = MAC_RADIO_SRC_MATCH_GET_SHORTADDR_EN();
- uint24 extAddrEnable = MAC_RADIO_SRC_MATCH_GET_EXTADDR_EN();
- uint24 enable = shortAddrEnable | extAddrEnable;
- if( macSrcMatchAddrMode == SADDR_MODE_SHORT )
- for( index = 0; index < MAC_SRCMATCH_SHORT_MAX_NUM_ENTRIES; index ++ )
- /* Both 2n bit of extAddrEnable and
- * corresponding bit of shortAddrEnable must be clear
- * in order to assume that the entry location for a short address
- * is not used.
- if( (extAddrEnable & ((uint24)0x01 << ((index/2)*2))) == 0 &&
- (shortAddrEnable & ((uint24)0x01 << index)) == 0 )
- return index;
- else
- for( index = 0; index < MAC_SRCMATCH_EXT_MAX_NUM_ENTRIES; index++ )
- * 2n bit and 2n+1 bit of shortAddrEnable must be clear in order
- * to assume that the entry location for an extended address
- * is not used.
- if( (enable & ((uint24)0x03 << (index*2))) == 0 )
- return index;
- return index;
- * @fn macSrcMatchCheckSrcAddr
- * @brief Check if a short or extended address is in the source address table.
- * This function shall not be called from ISR. It is not thread safe.
- * 64-bit MAC address to be checked in the source address table.
- * @return uint8 - index of the entry in the table. Return
- * MAC_SRCMATCH_INVALID_INDEX (0xFF) if address not found.
- static uint8 macSrcMatchCheckSrcAddr ( sAddr_t *addr, uint16 panID )
- uint8 index;
- uint8 *pAddr;
- uint8 entrySize;
- uint8 indexUsed;
- uint8 indexSize;
- uint8 ramEntry[MAC_SRCMATCH_EXT_ENTRY_SIZE];
- uint24 enable;
- Currently, shadow memory is not supported to optimize SPI traffic.
- if( addr->addrMode == SADDR_MODE_SHORT )
- pAddr = entry;
- entrySize = MAC_SRCMATCH_SHORT_ENTRY_SIZE;
- indexSize = 1;
- enable = MAC_RADIO_SRC_MATCH_GET_SHORTADDR_EN();
- else
- pAddr = addr->addr.extAddr;
- entrySize = MAC_SRCMATCH_EXT_ENTRY_SIZE;
- indexSize = 2;
- enable = MAC_RADIO_SRC_MATCH_GET_EXTADDR_EN();
- for( index = 0; index < MAC_SRCMATCH_SHORT_MAX_NUM_ENTRIES; index += indexSize )
- /* Check if the entry is enabled */
- if( macSrcMatchCheckEnableBit( index, enable ) == FALSE )
- continue;
- indexUsed = index / indexSize;
- /* Compare the short address or extended address */
- MAC_RADIO_SRC_MATCH_TABLE_READ( ( indexUsed * entrySize ), ramEntry, entrySize );
- if( osal_memcmp( pAddr, ramEntry, entrySize ) == TRUE )
- /* Match found */
- return indexUsed;
- return MAC_SRCMATCH_INVALID_INDEX;
- * @fn macSrcMatchSetPendEnBit
- * @brief Set the enable bit in the source address table
- * @return none
- static void macSrcMatchSetPendEnBit( uint8 index, uint8 macSrcMatchAddrMode )
- uint24 enable;
- uint8 buf[MAC_SRCMATCH_ENABLE_BITMAP_LEN];
- enable = MAC_RADIO_SRC_MATCH_GET_SHORTADDR_PENDEN();
- enable |= ( (uint24)0x01 << index );
- osal_buffer_uint24( buf, enable );
- MAC_RADIO_SRC_MATCH_SET_SHORTPENDEN( buf );
- else
- enable = MAC_RADIO_SRC_MATCH_GET_EXTADDR_PENDEN();
- enable |= ( (uint24)0x01 << ( index * EXT_ADDR_INDEX_SIZE ) );
- enable |= ( (uint24)0x01 << ( ( index * EXT_ADDR_INDEX_SIZE ) + 1 ) );
- MAC_RADIO_SRC_MATCH_SET_EXTPENDEN( buf );
- * @fn macSrcMatchSetEnableBit
- * @brief Set or clear the enable bit in the SRCMATCH EN register
- * @param option - true (set the enable bit), or false (clear the enable
- * bit)
- * @return none
- static void macSrcMatchSetEnableBit( uint8 index,
- bool option,
- uint8 macSrcMatchAddrMode )
- uint24 enable;
- MAC_RADIO_SRC_MATCH_SET_SHORTEN( enable );
- else
- enable |= ( (uint24)0x01 << ( index * EXT_ADDR_INDEX_SIZE) );
- MAC_RADIO_SRC_MATCH_SET_EXTEN( enable );
- else
- enable &= ~( (uint24)0x01 << index );
- else
- enable &= ~( (uint24)0x01 << ( index * EXT_ADDR_INDEX_SIZE ) );
- * @fn macSrcMatchCheckEnableBit
- * @brief Check the enable bit in the source address table
- * @param enable - enable register should be read before passing
- * it here
- static bool macSrcMatchCheckEnableBit( uint8 index, uint24 enable)
- if( enable & ((uint24)0x01 << index ))
- return TRUE;
- return FALSE;
- * @fn macSrcMatchGetShortAddrPendEnBit
- * @brief Return the SRCMATCH ShortAddr Pend enable bitmap
- * @param none
- * @return uint24 - 24 bits bitmap
- static uint24 macSrcMatchGetShortAddrPendEnBit( void )
- MAC_RADIO_GET_SRC_SHORTPENDEN( buf );
- return osal_build_uint32( buf, MAC_SRCMATCH_ENABLE_BITMAP_LEN );
- * @fn macSrcMatchGetExtAddrPendEnBit
- * @brief Return the SRCMATCH Extended Address Pend enable bitmap
- * @param none
- static uint24 macSrcMatchGetExtAddrPendEnBit( void )
- MAC_RADIO_GET_SRC_EXTENPEND( buf );
- * @fn macSrcMatchGetShortAddrEnableBit
- * @brief Return the SRCMATCH ShortAddr enable bitmap
- * @param none
- static uint24 macSrcMatchGetShortAddrEnableBit( void )
- MAC_RADIO_GET_SRC_SHORTEN( buf );
- * @fn macSrcMatchGetExtAddrEnBit
- * @brief Return the SRCMATCH ExtAddr enable bitmap
- * @param none
- static uint24 macSrcMatchGetExtAddrEnableBit( void )
- MAC_RADIO_GET_SRC_EXTEN( buf );
