- #include <stdio.h>
- #include <string.h>
- #include "RAK.h"
- #include "Nano1X2Series.h"
- #include "LY096BG30.h"
- #include "base64.h"
- #include "sensorinit.h"
- #include "DHT11.h"
- #define SMTP_BUFF 64
- #define RESEND 3
- #define SENDTIME 90 //3min=180s 180/2=90
- #define DEBUG_PRINTF(...) // printf(__VA_ARGS__)
- char base64[SMTP_BUFF];
- uint8_t g_u8RecData[1024];
- volatile int32_t g_i32pointer;
- volatile uint16_t time_DHT11[40];
- volatile uint32_t capture_count =0;
- uint16_t DHT11_D[2];
- extern void print_Line(uint8_t Line, char Text[]);
- /* SendMail: 如果你的邮箱是ic@126.com,想寄信给ee@139.com
- char *id:你的邮箱id,这里是ic
- char *pw:你的邮箱密码,自行填写******
- char *server:你的邮箱域名,126.com
- char *from: 你的邮箱全名,这里是ic@126.com
- char *to: 寄信目标地址,这里是ee@139.com
- char *subject:邮件标题,这里是Warning
- char *data:邮件内容,这里是Temp Over 30. Beep! To do or Not.
- int SendMail(char *id, char *pw, char *server, char *from, char *to, char *subject ,char *data);
- int mailcmd(char *cmd, char *content, char *expect);
- void TMR0_IRQHandler(void)
- time_DHT11[capture_count] = TIMER_GetCaptureData(TIMER0);
- capture_count++;
- TIMER_ClearCaptureIntFlag(TIMER0);
- int main()
- char tmp[SMTP_BUFF];
- uint32_t sendtime=0;
- SYS_Init();
- UART_Init();
- Init_DHT11();
- I2C_Init();
- WIFI_Init();
- while(1)
- CLK_SysTickDelay(2000000);
- Read_DHT11(DHT11_D);
- DEBUG_PRINTF("Humidity = %d\n", DHT11_D[0]);
- DEBUG_PRINTF("Temperature = %d\n", DHT11_D[1]);
- snprintf(tmp, SMTP_BUFF, "Temperature=%2d", DHT11_D[1]);
- print_Line(2, tmp);
- if((DHT11_D[1] > 30))
- if((sendtime % SENDTIME) == (SENDTIME-1))
- print_Line(1, "Send Mail Now ");
- if (SendMail("ic", "*******", \
- "126.com", "ic@126.com", "ee@139.com", \
- "Warning", "Temp Over 30. Beep! To do or Not."))
- DEBUG_PRINTF("Send Successful\r\n");
- print_Line(1, "Send Mail Ok ");
- sendtime = 0;
- else
- DEBUG_PRINTF("Send Failed\r\n");
- print_Line(1, "Send Mail Fail");
- sendtime = SENDTIME/3;
- sendtime = (sendtime > SENDTIME)?(0):(sendtime+1);
- else sendtime = 0;
- snprintf(tmp, SMTP_BUFF, "Send Time:%2d", sendtime);
- print_Line(3, tmp);
- int flag;
- flag = mailcmd("helo %s\r\n", server, "250");
- flag &= mailcmd("%sauth login\r\n", "", "334");
- encode_base64(base64 , id, strlen(id));
- flag &= mailcmd("%s\r\n", base64, "334");
- encode_base64(base64 , pw, strlen(pw));
- flag &= mailcmd("%s\r\n", base64, "235");
- flag &= mailcmd("mail from: <%s>\r\n", from, "250");
- flag &= mailcmd("rcpt to: <%s>\r\n", to, "250");
- flag &= mailcmd("%sdata\r\n", "", "354");
- flag &= mailcmd("from: %s\r\n", id, "");
- flag &= mailcmd("to: %s\r\n", to, "");
- flag &= mailcmd("subject: %s\r\n\r\n", subject, "");
- flag &= mailcmd("%s\r\n.\r\n", data, "250");
- flag &= mailcmd("%squit\r\n\r\n", "", "221");
- return flag;
- int i=1;
- while(1)
- snprintf(tmp, SMTP_BUFF, (const char *)cmd, content);
- RAK_UART_Send((uint8_t *)tmp, strlen(tmp));
- CLK_SysTickDelay(500000);
- DEBUG_PRINTF(tmp);
- DEBUG_PRINTF((char *)g_u8RecData);
- if(strstr((const char *)g_u8RecData, expect))
- break;
- if(++i > RESEND)
- return 0;
- return 1;
