在MAPLABX IDE里的基于芯片pic12f683的工程配置位窗口是空的???
 楼主| 52mcu 发表于 2015-10-19 19:50 | 显示全部楼层 |阅读模式
在MAPLABX IDE里的基于芯片pic12f683的工程配置位窗口是空的,
不能通过鼠标选择看门狗,震荡方式等,点“输出生成源代码”还是能能生成如下的配置代码。
这是为啥??其它工程却是正常的。
#pragma config FOSC = EXTRCCLK  // Oscillator Selection bits (EXTRC oscillator: External RC on RA5/OSC1/CLKIN, CLKOUT function on RA4/OSC2/CLKOUT pin)
#pragma config WDTE = ON        // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON       // MCLR Pin Function Select bit (MCLR pin function is MCLR)
#pragma config CP = OFF         // Code Protection bit (Program memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
#pragma config BOREN = ON       // Brown Out Detect (BOR enabled)
#pragma config IESO = ON        // Internal External Switchover bit (Internal External Switchover mode is enabled)
#pragma config FCMEN = ON
mahaokai 发表于 2015-10-22 14:50 | 显示全部楼层
你好,我们有一款pic12f683的单片机,价格便宜很多,有兴趣的话加我QQ给你发规格书,QQ:2355910802
