我在HT-IDE里写C程序中包含了<string.h>,编译时出现错误提示如下:<br /><br />伪指令progma的字符串`SAVE`无效<br />伪指令progma的字符串`REGPARMS`无效<br />伪指令progma的字符串`RESTORE`无效<br /><br />这是为什么呢?如果在UV2里面编译就不会出错。我用HT的IDE为什么就不行?补充:HT-IDE是台湾HOLTEK公司的IDE,有自己的库,只是我要用KEIL C里的<string.h>头文件,应该怎么办。<br />STRING.H是从KEIL C文件夹中INC子文件夹里找到的,内容如下:<br />/*--------------------------------------------------------------------------<br />STRING.H<br /><br />String functions.<br />Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.<br />All rights reserved.<br />--------------------------------------------------------------------------*/<br /><br />#ifndef _SIZE_T<br />#define _SIZE_T<br />typedef unsigned int size_t;<br />#endif<br /><br />#ifndef NULL<br />#define NULL ((void *) 0L)<br />#endif<br /><br />#pragma SAVE<br />#pragma REGPARMS<br />extern char *strcat (char *s1, char *s2);<br />extern char *strncat (char *s1, char *s2, int n);<br /><br />extern char strcmp (char *s1, char *s2);<br />extern char strncmp (char *s1, char *s2, int n);<br /><br />extern char *strcpy (char *s1, char *s2);<br />extern char *strncpy (char *s1, char *s2, int n);<br /><br />extern int strlen (char *);<br /><br />extern char *strchr (const char *s, char c);<br />extern int strpos (const char *s, char c);<br />extern char *strrchr (const char *s, char c);<br />extern int strrpos (const char *s, char c);<br /><br />extern int strspn (char *s, char *set);<br />extern int strcspn (char *s, char *set);<br />extern char *strpbrk (char *s, char *set);<br />extern char *strrpbrk (char *s, char *set);<br />extern char *strstr (char *s, char *sub);<br />extern char *strtok (char *str, const char *set);<br /><br />extern char memcmp (void *s1, void *s2, int n);<br />extern void *memcpy (void *s1, void *s2, int n);<br />extern void *memchr (void *s, char val, int n);<br />extern void *memccpy (void *s1, void *s2, char val, int n);<br />extern void *memmove (void *s1, void *s2, int n);<br />extern void *memset (void *s, char val, int n);<br />#pragma RESTORE |
