[技术问题解答] android fstab nomblk_io_submit
 楼主| mobz 发表于 2015-10-30 17:04 | 显示全部楼层 |阅读模式
有人知道下面这个挂载的时候的参数是什么意思吗?为什么要这样设置?
nomblk_io_submit
/dev/block/mmcblk0p4    /data        ext4    nosuid,nodev,nodiratime,noatime,nomblk_io_submit,noauto_da_alloc,errors=panic    wait,encryptable=footer
# Android fstab file.
#<src>                                                  <mnt_point>         <type>    <mnt_flags and options>                       <fs_mgr_flags>
# The filesystem that contains the filesystem checker binary (typically /system) cannot
# specify MF_CHECK, and must come before any filesystems that do specify MF_CHECK
/devices/platform/sdhci-esdhc-imx.1/mmc_host/mmc2 /mnt/extsd vfat defaults voldmanaged=sdcard:auto              //SDCARD
/devices/platform/fsl-ehci /mnt/udisk vfat defaults voldmanaged=sdcard:auto                                                            //U DISK
/dev/block/mmcblk0p5    /system      ext4    ro        wait
/dev/block/mmcblk0p6    /cache       ext4    nosuid,nodev,nomblk_io_submit                                                    wait
/dev/block/mmcblk0p7    /device      ext4    ro,nosuid,nodev        wait
/dev/block/mmcblk0p1    /boot        emmc    defaults        defaults
/dev/block/mmcblk0p2    /recovery    emmc    defaults        defaults
/dev/block/mmcblk0p8    /misc        emmc    defaults        defaults
李香兰 发表于 2015-10-30 21:37 | 显示全部楼层
我不是太懂,等大侠来回答
 楼主| mobz 发表于 2015-11-2 09:50 | 显示全部楼层
我不是太懂,等大侠来回答
非常感谢
