[i.MX] 求救:buildroot下编译的gstreamer不能播音频
 楼主| xsjkiver 发表于 2015-11-5 11:33 | 显示全部楼层 |阅读模式
如题,在buildroot(2015.08)下编译imx6dlsabreauto,编译后的gstreamer0.10可正常播放视频,但提示找不到音频解码器(beepdec)。使用gst-inspect工具查看此插件的信息发现有问题,如下:
# gst-inspect-0.10  beepdec
(gst-plugin-scanner:233): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_amrdec.so': lib_nb_amr_dec_arm9_elinux.sy
(gst-plugin-scanner:233): GStreamer-CRITICAL **: gst_element_class_add_pad_template: assertion 'GST_IS_PAD_TEMPLATE (templ)' failed
(gst-plugin-scanner:233): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_mp3enc.so': lib_mp3_enc_arm12_elinux.so.y
MAX resolution 1920x1080
(gst-plugin-scanner:233): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_audio_pp.so': lib_peq_arm11_elinux.so.1:y
(gst-plugin-scanner:233): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_mpeg2dec.so': lib_mpeg2_dec_arm11_elinuxy
(gst-plugin-scanner:233): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_h264dec.so': lib_H264_dec_arm11_elinux.s!
en shared object file: No such file or directory
(gst-plugin-scanner:233): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_mpeg4aspdec.so': lib_MPEG4ASP_dec_arm11_y
(gst-inspect-0.10:232): GStreamer-CRITICAL **: gst_element_class_add_pad_template: assertion 'GST_IS_PAD_TEMPLATE (templ)' failed
(gst-inspect-0.10:232): GStreamer-CRITICAL **: gst_pad_new_from_template: assertion 'GST_IS_PAD_TEMPLATE (templ)' failed
(gst-inspect-0.10:232): GStreamer-CRITICAL **: gst_pad_set_setcaps_function: assertion 'GST_IS_PAD (pad)' failed
(gst-inspect-0.10:232): GStreamer-CRITICAL **: gst_pad_set_chain_function: assertion 'GST_IS_PAD (pad)' failed
(gst-inspect-0.10:232): GStreamer-CRITICAL **: gst_pad_set_event_function: assertion 'GST_IS_PAD (pad)' failed
(gst-inspect-0.10:232): GStreamer-CRITICAL **: gst_element_add_pad: assertion 'GST_IS_PAD (pad)' failed
Factory Details:
  Long name:    beep audio decoder
  Class:        Codec/Decoder/Audio
  Description:  Decode compressed audio to raw data
  Author(s):    Multimedia Team
  Rank:         secondary + 1 (129)
Plugin Details:
  Description:          universal audio codec
  Filename:             /usr/lib/gstreamer-0.10/libmfw_gst_beep.so
  Version:              4.0.2
  License:              LGPL
  Source module:        gst-fsl-plugins
  Binary package:       Freescle Gstreamer Multimedia Plugins
  Origin URL:
GObject
+----GstObject
       +----GstElement
             +----GstBeepDec
Pad Templates:
  SRC template: 'src'
    Availability: Always
    Capabilities:
      audio/x-raw-int
                  width: { 16, 24, 32 }
                  depth: { 16, 24, 32 }
                   rate: { 7350, 8000, 11025, 12000, 16000, 22050, 24000, 32000, 44100, 48000, 64000, 88200, 96000 }
               channels: [ 1, 8 ]
Element Flags:
  no flags set
Element Implementation:
  Has change_state() function: gst_beepdec_state_change
Element has no clocking capabilities.
Element has no indexing capabilities.
Element has no URI handling capabilities.
Pads:
  SRC: 'src'
    Implementation:
      Has custom eventfunc(): gst_pad_event_default
      Has custom queryfunc(): gst_pad_query_default
        Provides query types:
                (2):    duration (Total duration)
      Has custom iterintlinkfunc(): gst_pad_iterate_internal_links_default
      Has getcapsfunc(): gst_pad_get_fixed_caps_func
      Has acceptcapsfunc(): gst_pad_acceptcaps_default
    Pad Template: 'src'
Element Properties:
  name                : The name of the object
                        flags: readable, writable
                        String. Default: "beepdec0"
  resync-threshold    : set threshold for resync timestamp: -1, disable resync
                        Integer64. Range: -1 - 9223372036854775807 Default: 2000000000
  reset-when-resync   : enable/disable reset when resync
                        Boolean. Default: true
  set-layout          : enable/disable set output channel layout
在其官方原版系统下(yocto),查看此插件的信息是正常的,如下:
Factory Details:
Plugin Details:
  Version:              4.0.2
  License:              LGPL
  Origin URL:
GObject
+----GstObject
       +----GstElement
             +----GstBeepDec
Pad Templates:
  SRC template: 'src'
    Capabilities:
      audio/x-raw-int
               channels: [ 1, 8 ]
  SINK template: 'sink'
    Capabilities:
      audio/x-vorbis
      audio/mpeg
            mpegversion: 1
      audio/mpeg
            mpegversion: { 2, 4 }
Element Flags:
  Has custom save_thyself() function: gst_element_save_thyself
  Has custom restore_thyself() function: gst_element_restore_thyself
Pads:
  SRC: 'src'
    Implementation:
    Pad Template: 'src'
  SINK: 'sink'
    Implementation:
      Has chainfunc(): gst_beepdec_chain
      Has custom eventfunc(): gst_beepdec_sink_event
      Has setcapsfunc(): gst_beepdec_setcaps
    Pad Template: 'sink'
Element Properties:
发现在buildroot系统下的beepdec比原版系统下的beepdec在“Pads”下少一个“SINK”。
有遇到过此问题的大神吗?
FSL_TICS_Rita 发表于 2015-11-5 15:26 | 显示全部楼层
楼主你好,关于你帖中的问题,建议你到https://community.freescale.com/community/imx/content这里提问。
mini1986 发表于 2015-11-6 10:29 | 显示全部楼层
顶起来,祝你早日解决问题,分享下经验......
 楼主| xsjkiver 发表于 2016-1-2 00:08 | 显示全部楼层
只需将/usr/lib/imx-mm/audio-codec/目录下的库文件(不包括wrap目录)以及/usr/lib/imx-mm/video-codec/目录下的库文件移动到/usr/lib/下即可
