[MSP430] MSP430F169单片机请各位高手看一下我的AT24C32N的时序为什么不行
 楼主| 王立文1314 发表于 2015-11-17 11:03 | 显示全部楼层 |阅读模式
#include"msp430x16x.h"
#define SDA_IN    P4DIR&=~BIT0
#define SDA_OUT   P4DIR|=BIT0
#define SDA_LOW   P4OUT&=~BIT0
#define SDA_HIGH  P4OUT|=BIT0
#define SCL_LOW   P4OUT&=~BIT1
#define SCL_HIGH  P4OUT&=~BIT1
#define        LED1_ON        P3OUT|=0x01                                //LED1电源控制信号
#define        LED2_ON        P3OUT|=0x02                                //LED2电源控制信号
#define        LED3_ON        P3OUT|=0x04                                //LED3电源控制信号
#define        LED_all_OFF        P3OUT&=0xF8                        //LED电源全部灭
const unsigned char disp_led[16]={        //7段显示笔划
                                        0X77,0X11,0X5E,0X5B,0X39,0X6B,0X6F,0X51,0X7F,0X7B,
                                        0X08,0X00,0X66,0X3D,0X26,0X7D};//0123456789- CHLA;
void delay_ms(unsigned char ms)
   unsigned char t;
   while(ms--)
   for(t=0;t<5000;t++);
     _NOP();
void delay_us(unsigned char us)
   unsigned char t;
   while(us--)
   for(t=0;t<4;t++);
     _NOP();
void start(void)
     SDA_OUT;
     delay_us(20);
     SDA_HIGH;
     delay_us(3);
     SCL_HIGH;
     delay_us(2);
     SDA_LOW;
     delay_us(5);
     SCL_LOW;
     delay_us(10);
void stop(void)
    SDA_OUT;
    SDA_LOW;
    delay_us(2);
    SCL_HIGH;
    delay_us(2);
    SDA_LOW;
    delay_us(2);
    SDA_HIGH;
void ack(void)
   SDA_OUT;
   SDA_LOW;
   delay_us(2);
   SCL_LOW;
   delay_us(2);
   SCL_HIGH;
   delay_us(2);
   SCL_LOW;
   SDA_HIGH;
void noack(void)
   SDA_OUT;
   SDA_HIGH;
   delay_us(2);
   SCL_LOW;
   delay_us(2);
   SCL_HIGH;
   delay_us(2);
   SCL_LOW;
unsigned char check_ack(void)
    unsigned char i;
    SDA_IN;
    SCL_HIGH;
   delay_us(2);
   if(P4IN&0X01)
      i=0;
   else
      i=1;
   SCL_LOW;
   delay_us(2);
   SDA_OUT;
   return i;
void write(unsigned char data)
   unsigned char tem;
   SDA_OUT;
   SCL_LOW;
   for(tem=0;tem<8;tem++)
      if(data&0x80)
         SDA_HIGH;
      else
        SDA_LOW;
   delay_us(2);
   SCL_HIGH;
   delay_us(2);
   SCL_LOW;
   delay_us(2);
   data<<=1;
   SDA_HIGH;
   delay_us(15);////////////////////////需要加SDA_HIGH;
unsigned char read(void)
   unsigned char tem;
    unsigned char dat;
   SDA_IN;
   SCL_LOW;
   delay_us(2);
     SCL_HIGH;
     delay_us(2);
     dat<<=1;
     if(P4IN&0X01)
       dat|=0x01;
      else
        dat&=0xfe;
      SCL_LOW;
    SDA_LOW;
     SDA_OUT;///////////////////////需要加SDA_LOW;
   return dat;
unsigned char write_init(unsigned int addr,unsigned char data)
  start();   //////////////////////////
  write(0XA0);/////////////////////////
  if(check_ack==0)
    return 0x55;
  write(0X00);//////////////////////////
  if(check_ack==0)
    return 0x55;
   write(addr);///////////////////////
   if(check_ack==0)
    return 0x55;
   write(data);///////////////////////
     if(check_ack==0)
    return 0x55;
  stop();////////////////////////////
  delay_ms(10);
  return 0;
unsigned char read_init(unsigned char addr)
  unsigned char ch;
  start();/////////////////////////////
if(check_ack==0)
    return 0x55;
//delay_ms(5);
  if(check_ack==0)
    return 0x55;
  write(addr);///////////////////////位地址
if(check_ack==0)
    return 0x55;
delay_ms(5);
start();
write(0XA1);
if(check_ack==0)
    return 0x55;
//delay_ms(5);
ch=read();
noack();
stop();
delay_us(100);
return ch;
void port(void)
        P1DIR =0x0f;
        P1SEL = 0;
        P1OUT = 0xff;
        P2DIR=0xff;
        P2SEL=0x00;
        P2OUT=0x00;
        P3DIR=0x17;
        P3SEL=0x30;
        P3OUT=0x00;
        P4DIR = 0x03;
        P4SEL = 0;
void main(void)
  unsigned char value=0;
  unsigned char val;
  WDTCTL = WDTPW + WDTHOLD;
   port();
while(1)
               LED_all_OFF;
           value++;
         write_init(10,value);
            if(value==10)
             value=0;
         delay_ms(300);
            val=read_init(10);
           LED1_ON;
          P2OUT=disp_led[val];
          delay_ms(300);
ayb_ice 发表于 2015-11-17 11:34 | 显示全部楼层
应该先输出数据再设置为输出端口,否则可能导致数据瞬间错误,从而导致模拟失败
 楼主| 王立文1314 发表于 2015-11-17 14:27 | 显示全部楼层
那我的程序整体没问题吧,只是输出方向的问题吗 ,麻烦您了,我也是刚学的430,谢谢您。
ayb_ice 发表于 2015-11-17 15:09 | 显示全部楼层
那我的程序整体没问题吧,只是输出方向的问题吗 ,麻烦您了,我也是刚学的430,谢谢您。 ...
那没有看了,一步步调试吧
dirtwillfly 发表于 2015-11-18 08:35 | 显示全部楼层
时序看代码是看不出来的,建议用逻辑分析仪观察一下
