[LPC] lpc1768中断问题
 楼主| gao695600808 发表于 2015-11-17 15:47 | 显示全部楼层 |阅读模式
第0第1  p2.10,p2.11外部中断是编码器,第三是gpio中断p2.9按键用中断三通道  问题是  中断三使能可进入中断三  旋转编码器此时无法进入中断01 程序跳入中断三并无法出中断三    关闭中断三  中断01可用,想到优先级问题,NVIC_SetPriority(EINT3_IRQn,5); 已近降级中断三优先级了,可还是无法进入中断01
#define EINT0               0x00000001
#define EINT1               0x00000002
#define EINT3               0x00000008
void EINT0_IRQHandler(void);
void interruptInit( void );
volatile uint32_t plus=1;
void interruptInit(void)
LPC_PINCON->PINSEL4 &= ~0x00f00000;
LPC_PINCON->PINSEL4 |=  0x00500000;
 楼主| gao695600808 发表于 2015-11-17 15:50 | 显示全部楼层
LPC_SC->EXTMODE  |= 0x00000003;
LPC_SC->EXTPOLAR |= 0x00000001;
LPC_GPIOINT->IO2IntEnF |= 1<<10;
LPC_GPIOINT->IO2IntEnR |= 1<<11;
LPC_PINCON->PINSEL4 &= ~(0X03L<<18);
LPC_PINCON->PINMODE4 &= ~(0X03L<<18);
LPC_PINCON->PINMODE_OD2 &= ~(0X01<<9);
LPC_GPIOINT->IO2IntEnF |= 1<<9;
NVIC_SetPriority(EINT0_IRQn,0);
NVIC_SetPriority(EINT1_IRQn,0);
NVIC_EnableIRQ(EINT0_IRQn);
NVIC_EnableIRQ(EINT1_IRQn);
NVIC_EnableIRQ(EINT3_IRQn);
void EINT0_IRQHandler (void)
        NVIC_DisableIRQ(EINT0_IRQn);
        //NVIC_DisableIRQ(EINT3_IRQn);
  LPC_SC -> EXTINT = EINT0;         //clear interrupt
        if((LPC_GPIO2->FIOPIN & 1<<11)==0)
                Delay(10);
                ++plus;
                        UART1_SendString("+++");
        else //if((LPC_GPIO2->FIOPIN & 1<<11)!=0)
                if(plus>0)
                --plus;
                        UART1_SendString("---");
//NVIC_EnableIRQ(EINT3_IRQn);
void EINT1_IRQHandler (void)
        NVIC_DisableIRQ(EINT1_IRQn);
        LPC_SC -> EXTINT = EINT1;         //clear interrupt
        if((LPC_GPIO2->FIOPIN & 1<<10)!=0)
                Delay(10);
                        if(plus>0)
                                --plus;
        else //if((LPC_GPIO2->FIOPIN & 1<<10)==0)
                ++plus;
void EINT3_IRQHandler(void)
//void eint3(void)
                LPC_SC -> EXTINT = EINT3;         //clear interrupt
    //NVIC_ClearPendingIRQ(EINT3_IRQn);
                 if(LPC_GPIOINT->IntStatus &(1<<2))//Èç¹ûp2.x¶Ë¿ÚÓÐÖжÏ
                        if(LPC_GPIOINT->IO2IntStatF &(1<<9))//p2.9ÓÐÖжÏ
                                  LPC_GPIOINT->IO2IntClr |= (1<<9);//ÖжÏÇåÁã
                                 if((LPC_GPIO2->FIOPIN1 & 1<<1)==0)
                                        ++plus;
                                                UART1_SendString("///");
 楼主| gao695600808 发表于 2015-11-17 15:59 | 显示全部楼层
已解决 发出来时 脑袋一抽就想到了
这俩
是配置gpio中断的
