收藏1 举报
/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2011 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ #include <stdio.h> #include <stdint.h> #include "M051.h" #include "Register_Bit.h" #include "Uart.h" /*en:************************************************************************************ Description: Initialize UART. ****************************************************************************************/ /*中:************************************************************************************ 描述: 初始化UART ****************************************************************************************/ void UART_Init(void) { P3_MFP = P3_MFP & (~(P31_TXD0 | P30_RXD0)) | (TXD0 | RXD0); //配置P3.1和P3.0为UART功能//en:Set P3.1 and P3.0 to UART0 function IPRSTC2 |= UART0_RST; //复位UART模块//en:Reset UART0 module IPRSTC2 &= ~UART0_RST; //UART模块从复位状态恢复到正常工作状态//en:Resume UART0 to normal mode APBCLK |= UART0_CLKEN; //使能UART时钟//en:Enable UART0 clock CLKSEL1 = CLKSEL1 & (~UART_CLK) | UART_12M; //选择外部12M作为UART时钟源//en:Select external 12M as UART0 clock source CLKDIV &= ~(15<<8); //设置UART时钟除频值为0//en:UART clock no division UA0_FCR |= TX_RST; //复位发送FIFO//en:Reset transmit FIFO UA0_FCR |= RX_RST; //复位接收FIFO//en:Reset receive FIFO UA0_LCR &= ~PBE; //校验位禁止//en:None parity UA0_LCR = (UA0_LCR & (~WLS)) | WL_8BIT; //数据宽度为8位//en:Data width 8 bits UA0_LCR &= NSB_ONE; //1位停止位//en:1 bit stop UA0_BAUD |= DIV_X_EN; //模式2:DIV_X_EN = 1//en:Mode2:DIV_X_EN = 1 UA0_BAUD |= DIV_X_ONE; //模式2:DIV_X_ONE =1//en:Mode2:DIV_X_ONE = 1 UA0_BAUD |= ((12000000 / 115200) - 2); //设置波特率为115200,模式2波特率=UART_CLK/(UA_BAUD+2)//en:Set BaudRate to 115200,BaudRate==UART_CLK/(UA_BAUD+2) in mode 2 } /*en:************************************************************************************ Parameter: c: char to be sent. Description: Send a char to PC. ****************************************************************************************/ /*中:************************************************************************************ 参数 : c: 要发送到字符 描述: 发送一个字符到PC ****************************************************************************************/ void Send_Data_To_PC (uint8_t c) { while((UA0_FSR&TX_FULL) != 0); //发送FIFO满时等待//en:Wait until UART transmit FIFO is not full UA0_THR = (uint8_t) c; //通过UART0发送一个字符//en:Transmit a char via UART0 } /*en:************************************************************************************ Return: A char. Description: Get a char from PC. ****************************************************************************************/ /*中:************************************************************************************ 返回值: 一个字符 描述: 从PC获取一个字符 ****************************************************************************************/ uint8_t Receive_Data_From_PC(void) { while((UA0_FSR&RX_EMPTY) != 0); //等字符//en:Wait until an avaliable char present in RX FIFO return ((uint8_t)UA0_RBR); //返回接收到的字符//en:Return received char } void Show_Pass(void) { printf ("\n"); printf ("\n"); printf (" * * * * * \n"); printf (" * * * * \n"); printf (" * * * * \n"); printf (" * * * * \n"); printf (" * * * * \n"); printf (" * * * * \n"); printf (" * * * * \n"); printf (" * * * * \n"); printf (" * * * * \n"); printf (" * * * * \n"); printf (" * * * * * \n"); printf ("\n"); printf ("\n"); } void Show_Fail(void) { printf ("\n"); printf ("\n"); printf (" * * \n"); printf (" * * \n"); printf (" * * \n"); printf (" * * \n"); printf (" * * \n"); printf (" * \n"); printf (" * * \n"); printf (" * * \n"); printf (" * * \n"); printf (" * * \n"); printf (" * * \n"); printf ("\n"); printf ("\n"); }
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
223
3738
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
