今天这个程序很简单
首先,新建一个ASF工程,然后选择XMEGA-B1开发板,则该板上的LED及SPI还有USART都已经定义好了。
如下程序:
- #ifndef _XMEGA_B1_XPLAINED_H_
- #define _XMEGA_B1_XPLAINED_H_
- #include "compiler.h"
- #include "conf_board.h"
- #include "gpio.h"
- /*! \name Miscellaneous data
- //! Validate board support for the common sensor service.
- #define COMMON_SENSOR_PLATFORM
- /*! \name Voltages
- #define VCC_TARGET 3.30
- #define VCC_ANA 3.30
- #define VCC_USB 5.00
- /*! \name ADC Connection of the Temperature Sensor
- #define TEMPERATURE_SENSOR_ADC_MODULE ADCB
- #define TEMPERATURE_SENSOR_ADC_INPUT ADCCH_POS_PIN0
- #define TEMPERATURE_SENSOR_SIGNAL_PIN IOPORT_CREATE_PIN(PORTB,0)
- /*! \name ADC Connection of the Light Sensor
- #define LIGHT_SENSOR_ADC_MODULE ADCB
- #define LIGHT_SENSOR_ADC_INPUT ADCCH_POS_PIN2
- #define LIGHT_SENSOR_SIGNAL_PIN IOPORT_CREATE_PIN(PORTB,2)
- /*! \name ADC Connection of the Potentiometer
- #define POTENTIOMETER_ADC_MODULE ADCB
- #define POTENTIOMETER_ADC_INPUT ADCCH_POS_PIN1
- #define POTENTIOMETER_SIGNAL_PIN IOPORT_CREATE_PIN(PORTB,1)
- /*! \name ADC Connection of the External Voltage Input
- #define EXT_VIN_ADC_MODULE ADCB
- #define EXT_VIN_ADC_INPUT ADCCH_POS_PIN3
- #define EXT_VIN_SIGNAL_PIN IOPORT_CREATE_PIN(PORTB,3)
- /*! \name Common ADC module used for on-board sensor.
- #define BOARD_SENSOR_ADC_MODULE ADCB
- /*! \name USER LEDs
- #define USERLEDPORT PORTB
- #define USERLEDMASK (0xF0)
- #define USERLED0POS PIN4_bp
- static inline void user_led_set(uint8_t b)
- USERLEDPORT.OUT = b << USERLED0POS;
- static inline void user_led_toggle(void)
- USERLEDPORT.OUTTGL = USERLEDMASK;
- /*! \name Touch
- #define TOUCHPORT PORTE
- #define TOUCHMASK (0x0F)
- #define TOUCH0POS PIN0_bp
- static inline bool is_touch0(void)
- if (TOUCHPORT.IN & (1<<(TOUCH0POS ))) return false;
- else return true;
- static inline bool is_touch1(void)
- if (TOUCHPORT.IN & (1<<(TOUCH0POS+1))) return false;
- else return true;
- /* If USARTE0 is enabled, touch buttons CS2 and CS3 will not work, as they
- * share pins with the USART. These functions are then not defined if the user
- * tries to use them, generating an error rather than
- * the buttons not working. */
- #ifndef CONF_BOARD_ENABLE_USARTE0
- static inline bool is_touch2(void)
- if (TOUCHPORT.IN & (1<<(TOUCH0POS+2))) return false;
- else return true;
- static inline bool is_touch3(void)
- if (TOUCHPORT.IN & (1<<(TOUCH0POS+3))) return false;
- else return true;
- #endif
- static inline uint8_t touch_get(void)
- return (((~TOUCHPORT.IN) & TOUCHMASK) << TOUCH0POS);
- /*! \name LCD BACKLIGHT
- #define BACKLIGHTPORT PORTE
- #define BACKLIGHT_GPIO IOPORT_CREATE_PIN(PORTE,5)
- #define BACKLIGHT_TIMER TCE0
- #ifndef BACKLIGHT_TIMER_FREQUENCY
- #define BACKLIGHT_TIMER_FREQUENCY 2000000
- #endif
- #ifndef BACKLIGHT_TIMER_COUNT
- #define BACKLIGHT_TIMER_COUNT 0x7FFF
- #endif
- static inline void backlight_on(void)
- gpio_set_pin_high(BACKLIGHT_GPIO);
- static inline void backlight_off(void)
- gpio_set_pin_low(BACKLIGHT_GPIO);
- static inline void backlight_toggle(void)
- gpio_toggle_pin(BACKLIGHT_GPIO);
- /*! \name Number of LEDs.
- #define LED_COUNT 4
- /*! \name GPIO Connections of LEDs
- #define LED0_GPIO IOPORT_CREATE_PIN(PORTB,4)
- #define LED1_GPIO IOPORT_CREATE_PIN(PORTB,5)
- #define LED2_GPIO IOPORT_CREATE_PIN(PORTB,6)
- #define LED3_GPIO IOPORT_CREATE_PIN(PORTB,7)
- #define LED_POWER IOPORT_CREATE_PIN(PORTE,4)
- #define LED0 LED0_GPIO
- #define LED1 LED1_GPIO
- #define LED2 LED2_GPIO
- #define LED3 LED3_GPIO
- /*! \name GPIO Connections of Push Buttons
- * Warning, PB4 to PB7 are available only if JTAG is disabled.
- #define GPIO_PUSH_BUTTON_0 IOPORT_CREATE_PIN(PORTE,0)
- #define GPIO_PUSH_BUTTON_1 IOPORT_CREATE_PIN(PORTE,1)
- #define GPIO_PUSH_BUTTON_2 IOPORT_CREATE_PIN(PORTE,2)
- #define GPIO_PUSH_BUTTON_3 IOPORT_CREATE_PIN(PORTE,3)
- /*! \name SPI Connections of the AT45DBX Data Flash Memory
- #define AT45DBX_SPI &USARTC0
- #define AT45DBX_CS IOPORT_CREATE_PIN(PORTD,2)
- #define AT45DBX_MASTER_SCK IOPORT_CREATE_PIN(PORTC,5) // SCK as output
- #define AT45DBX_MASTER_MOSI IOPORT_CREATE_PIN(PORTC,7) // MOSI as output
- #define AT45DBX_MASTER_MISO IOPORT_CREATE_PIN(PORTC,6) // MISO as input
- #define AT45DBX_SPI_CLK_MASK SYSCLK_PORT_C
- //! \name MXT143E Xplained top module
- #define MXT143E_XPLAINED_TWI &TWIC
- #define MXT143E_XPLAINED_USART_SPI &USARTC0
- #define MXT143E_XPLAINED_CS IOPORT_CREATE_PIN(PORTC, 4)
- #define MXT143E_XPLAINED_SCK IOPORT_CREATE_PIN(PORTC, 7)
- #define MXT143E_XPLAINED_MOSI IOPORT_CREATE_PIN(PORTC, 5)
- #define MXT143E_XPLAINED_MISO IOPORT_CREATE_PIN(PORTC, 6)
- #define MXT143E_XPLAINED_CHG IOPORT_CREATE_PIN(PORTC, 2)
- #define MXT143E_XPLAINED_DC IOPORT_CREATE_PIN(PORTC, 3)
- #define MXT143E_XPLAINED_BACKLIGHT IOPORT_CREATE_PIN(PORTA, 4)
- #define MXT143E_XPLAINED_LCD_RESET IOPORT_CREATE_PIN(PORTA, 6)
- /*! \name Power ON LED management
- static inline void led_power_on(void)
- gpio_set_pin_high(LED_POWER);
- static inline void led_power_off(void)
- gpio_set_pin_low(LED_POWER);
- /*! \name External oscillator
- #define BOARD_XOSC_HZ 8000000
- #define BOARD_XOSC_TYPE XOSC_TYPE_XTAL
- #define BOARD_XOSC_STARTUP_US 2000
- #ifdef CONF_BOARD_LCD_BACKLIGHT_PWM
- void backlight_set_pwm(uint16_t pwm);
- uint16_t backlight_get_pwm(void);
- void backlight_stop_pwm(void);
- void backlight_start_pwm(void);
- #endif
- #endif // _XMEGA_B1_XPLAINED_H_
上边的:
则可以看出,用LED0,也可以写LED0_GPIO
看了一下硬件:
这四个管脚都接在了端口B上。
以下是程序:里边的换哪个写法效果都一样地
- #include <asf.h>
- int main (void)
- /* Insert system clock initialization code here (sysclk_init()). */
- //sysclk_init();
- board_init();
- //ioport_set_pin_high(LED0);
- //ioport_set_pin_high(LED1);
- //ioport_set_pin_high(LED2);
- //ioport_set_pin_high(LED3);
- ioport_set_pin_high(LED0_GPIO);
- ioport_set_pin_high(LED1_GPIO);
- ioport_set_pin_high(LED2_GPIO);
- ioport_set_pin_high(LED3_GPIO);
- while(1);
- /* Insert application code here, after the board has been initialized. */
以下运行效果:
