请大家帮忙看看这段VHDL哪里有问题?
 楼主| sdnd2000 发表于 2007-5-4 16:35 | 显示全部楼层 |阅读模式
小弟是初学者,才写的1位全加器的代码,用MAX+plus的,老是报这样的错:node'\mux21a:u2\:23.in1'&nbsp;missing&nbsp;source,&nbsp;麻烦大家帮忙看看<br />,谢谢!<br />library&nbsp;ieee;<br />use&nbsp;ieee.std_logic_1164.all;<br />entity&nbsp;muxk&nbsp;is&nbsp;<br />port&nbsp;(a1,a2,a3,s0,s1:&nbsp;in&nbsp;std_logic;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;outy&nbsp;:&nbsp;out&nbsp;std_logic);<br />end&nbsp;entity&nbsp;muxk;<br />architecture&nbsp;a&nbsp;of&nbsp;muxk&nbsp;is&nbsp;<br />component&nbsp;mux21a<br />port&nbsp;(&nbsp;a,b,s:&nbsp;in&nbsp;std_logic;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;y:&nbsp;out&nbsp;std_logic);<br />end&nbsp;component&nbsp;;<br />signal&nbsp;tmp:&nbsp;std_logic;<br />begin<br />u1:&nbsp;mux21a&nbsp;port&nbsp;map&nbsp;(&nbsp;a=&gta2,&nbsp;b=&gta3,s=&gts0);<br />u2:&nbsp;mux21a&nbsp;port&nbsp;map&nbsp;(&nbsp;a=&gta1,&nbsp;b=&gttmp,&nbsp;s=&gts1,y=&gtouty);<br />end&nbsp;architecture&nbsp;a;<br /><br />library&nbsp;ieee;<br />use&nbsp;ieee.std_logic_1164.all;<br />entity&nbsp;mux21a&nbsp;is<br />port(a,b&nbsp;:&nbsp;in&nbsp;&nbsp;std_logic;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;s:&nbsp;in&nbsp;std_logic;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;y:&nbsp;out&nbsp;std_logic);<br />end&nbsp;mux21a&nbsp;;<br />architecture&nbsp;b_mux21a&nbsp;of&nbsp;mux21a&nbsp;is<br />begin<br />&nbsp;&nbsp;y&lt=(a&nbsp;and&nbsp;(not&nbsp;s))&nbsp;or&nbsp;(b&nbsp;and&nbsp;s);<br />end&nbsp;b_mux21a;<br /><br />library&nbsp;ieee;<br />use&nbsp;ieee.std_logic_1164.all;<br />entity&nbsp;mux21a&nbsp;is<br />port(a,b&nbsp;:&nbsp;in&nbsp;&nbsp;std_logic;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;s:&nbsp;in&nbsp;std_logic;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;y:&nbsp;out&nbsp;std_logic);<br />end&nbsp;mux21a&nbsp;;<br />architecture&nbsp;b_mux21a&nbsp;of&nbsp;mux21a&nbsp;is<br />begin<br />&nbsp;&nbsp;process&nbsp;(a,b,s)<br />begin<br />if&nbsp;s='0'&nbsp;then&nbsp;y&lt=a;<br />else&nbsp;y&lt=b;<br />end&nbsp;if;<br />end&nbsp;process;<br />end&nbsp;b_mux21a;<br />
zjy32508wj 发表于 2007-5-6 20:35 | 显示全部楼层
你调用的两个模块都取名为mux21a,应该不行吧
 楼主| sdnd2000 发表于 2007-5-6 21:05 | 显示全部楼层
改了名字,也报同样的错啊
改了名字,也报同样的错啊
xqhe 发表于 2007-5-7 11:03 | 显示全部楼层
随便说说
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;这个也叫全加器吗?怎么偶怎么看都象是错误的三算一器件?惭愧,!
joy1zhou 发表于 2007-5-7 17:52 | 显示全部楼层
end architecture a;
sibaidong 发表于 2007-5-8 09:49 | 显示全部楼层
元件例化语句没有写好
&nbsp;&nbsp;&nbsp;&nbsp;你调用的是两个模块,而你却例化了一个模块的端口,第二模的端口找不到当然就出错了哦<br />&nbsp;&nbsp;&nbsp;&nbsp;还有,两个模块的名字最好不要相同,加以区分可读性也增强了!<br />&nbsp;&nbsp;&nbsp;&nbsp;
 楼主| sdnd2000 发表于 2007-5-8 22:53 | 显示全部楼层
谢谢大家
谢谢大家
