我新建了一个空的工程, 然后添加了一个CSD模块,并且通过CSD Wizard设置了数量、IO, 然后生成了应用程序代码,但是总是编译不通过,不知道是什么原因? 下面是编译的信息:
Starting MAKE... creating project.mk
lib/csd_1.asm
!WC:\Documents and Settings\yang.bo\桌面\ss\ss\ss\lib\csd_1.asm(189):(188) constant expression required (warning)
!WC:\Documents and Settings\yang.bo\桌面\ss\ss\ss\lib\csd_1.asm(512):(188) constant expression required (warning)
lib/csd_1hl.asm
lib/csd_1int.asm
lib/csd_1table.asm
lib/psocconfig.asm
lib/psocconfigtbl.asm
./boot.asm
./main.asm
sed: can't read HTlinkOpts.lkp: No such file or directory
expanded_libs =
Linking..
HI-TECH C COMPILER (Cypress PSOC) Lite V9.61PL1
Copyright (C) 1984-2008 HI-TECH SOFTWARE
(1273) Omniscient Code Generation not available in Lite mode (warning)
: 0: (499) undefined symbol: (error)
ffffffff(./obj/main.obj)
C:\PROGRA~1\Cypress\Common\CYPRES~2\tools\make: *** [output/ss.hex] Error 1
ss - 1 error(s) 2 warning(s) 17:54:39 |
